major flat spot when reving Engain "please look"
Old 07-14-2007, 08:04 PM   #1
Ride:  92 civic hb
Rep Power: 6 elpayaso201 is on a distinguished road
Send a message via AIM to elpayaso201
Angry major flat spot when reving Engain "please look"
ok i have a 91 ls b18a1 in my 92 cx and every time i rev my ingain it has big flat spots were it wont rev. and as u let off it well rev up but if i hit the gas again it will want to die Please help want to drive my car asap what could be causing this fuel regulator??? injectors????
elpayaso201 is offline   Reply With Quote
Old 07-14-2007, 08:10 PM   #2
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
"flat spot"?
http://pandora.com/
Old 07-14-2007, 08:12 PM   #3
Ride:  92 civic hb
it spuders or dose not rev up smothly
Old 07-14-2007, 08:33 PM   #4
formby's Avatar
does it need a tune up?
codes?
http://pandora.com/
Old 07-14-2007, 08:43 PM   #5
Ride:  92 civic hb
no it has new everything just did my swap
Old 07-14-2007, 09:14 PM   #6
formby's Avatar
ok
did you do a Tbelt... if so did you check that the teeth on the cam gears line up?
http://pandora.com/
Old 07-14-2007, 09:27 PM   #7
Ride:  92 civic hb
the teeth all line up the time belt is good all valves are good i think it a gas problem i put a new fuel filter and gas pump
Old 07-14-2007, 09:29 PM   #8
Ride:  92 civic hb
is the fuel pump presure on the civic the same as the on in the integra
