Mini-me d16a6/y8 wiring info, (vtec & distributor)
Old 03-22-2007, 03:10 PM   #1
Rep Power: 0 audiimportech has a little shameless behaviour in the past
Default Mini-me d16a6/y8 wiring info, (vtec & distributor)
Ok, just to clarify, I don't want to convert to obd1 or at least not yet. I already have a 90 civic si and a y8 head. So I'm looking for information on a few things and information on mini-me's is usually all jumbled about on forums it seems.
- Can I use my d16a6 distributor on y8 head without modification (i've been told yes before...)
- I need to know how to engage vtec. I want to engage it with rpm. (I'm under the impression it normally engages by oil pressure. Or what else is the oil pressure switch for?) What pin(s) on the ecu do I need to wire to the solenoid?
- I'm going to chip my ecu. Would turboedit be best to use?
- Which timing belt should I use a6, z6, or y8
-Lastly, I've considered getting a vafc but I'd like to just chip my ecu for now explore all my options except going obd1 for now (budget build) Thanks!!!
audiimportech is offline   Reply With Quote
Old 03-22-2007, 09:35 PM   #2
anyone?
Old 03-28-2007, 01:19 AM   #3
Deadnutsac
deadnutsac's Avatar
Ride:  90 CRX SI all stock
Rep Power: 7 deadnutsac is on a distinguished road
A6 dizzys work on y8 heads the z6 require mods. Use TurboEdit.
the sac is bac
deadnutsac is offline   Reply With Quote
obd2 vtec wiring issues... NARKOSIS HYBRID -> EG-EK / DC 0 11-05-2006 06:58 PM
vtec wiring!! tecdippin03 ECU's, Electronics, and Tuning 1 10-10-2006 08:59 PM
vtec wiring for a jdm d15b swap? 92civy HYBRID -> EG-EK / DC 1 09-07-2006 07:22 PM
Vtec wiring 91 integra cycloneb18c3 HYBRID -> ED-EF / DA 0 02-21-2004 12:38 PM
