mini me swap
Old 10-03-2006, 01:53 PM   #1
Ride:  91si
Rep Power: 6 tylerf1000 is on a distinguished road
Default mini me swap
I was just wondering about these swaps
my bro has a 89 crx, d15
and i have a 91 civic si d16a6 that i am going to be taking out, to put a b series in
can i just swap heads and give him the d16 head to put on a d15 block??
Would i have to swap anything else to the d15 or just the head??
what kinda power increase should i expect??
tylerf1000 is offline   Reply With Quote
Old 10-03-2006, 02:28 PM   #2
ef8
Rep Power: 9 ef8 is an unknown quantity at this point
Well it wouldnt really be considered a mini me.Normally a mini me is a sohc non-vtec block with a sohc vtec head.The head will bolt on with no problems.Also you could just go ahead to do a mpfi swap and that will give you a good power gain.However just by putting the a6 head on your probably not going to get very much of a power increase if any.
ef8 is offline   Reply With Quote
Old 10-03-2006, 11:14 PM   #3
Ride:  91si
what year and kinda civic has the v-tec sohc head??
What kinda gains would i get putting it on the d16a6
What kinda gains would i get putting it on the d15 block??
Old 10-04-2006, 12:33 AM   #4
ef8
you can either use the d16z6 from 92-95 ex or si hatch,or the d16y8 from a 96-98 ex.You can get pretty good gains from a sohc vtec head swap.Just make sure his crx is converted to mpfi.
Old 10-05-2006, 03:43 AM   #5
gettocrx's Avatar
Rep Power: 14 gettocrx is an unknown quantity at this point
Send a message via AIM to gettocrx
well if you use a a6 head... the difference is the cam and that its multi point fuel injection (4 injectors insted of 2), also the distributor has 1 extra sensor (2 more wires)! SO just swap out the cam and convert to mpfi
OR....
1)If you want to do a mini-me use a y8 head from a 96-00civic ex because the ef distributors will bolt right up so you wont have to switch over to obd1....If you do it that way just add a rpm switch or vtec controller to control vtec! a little ghetto but hey it works and its cheap.
2) If money is not problem switch over to obd1 and mpfi. get a p28 and get any sohc-v head.
Either way you'll have fun with wiring!
power wise... like jdm d15b vtec
b16 with one cam!
GETTO GARAGE: May be GHETTO but we get the job done!
88 CRX: B16A 60-1 turbo
94 HATCH: Daily Driven B16A (RIP)
92 EG8: Daily Driven 4DR Sleeper w/d16z6 t3/t04e turbo
NA IS ALRIGHT! but... BOOST IS BETTER!
gettocrx is offline   Reply With Quote
Old 10-05-2006, 11:10 AM   #6
ef8
adding a "vtec switch" isnt gonna do anything except make you run lean.If your going to want vtec to actually work and do what its supposed to do then your going to need to convert to obd1 and run a p28.When you add a vtec switch all your doing is putting power to the solenoid which isnt doing anything good,your going to need to run a p28 because it will change your timing,add fuel and all that good stuff you wouldnt be getting from a switch when in vtec.
Old 11-27-2006, 11:54 AM   #7
Ride:  94 dx hatch
Rep Power: 0 eghatch is on a distinguished road
Default mini swap
i just put a 98 dx motor into my 94 dx hatch and i was wondering what exactly do i need to make the y8 head run right. if there is anybody who knows please reply
eghatch is offline   Reply With Quote
Old 11-27-2006, 01:34 PM   #8
Rep Power: 0 russianswty is on a distinguished road
And dont forget to use the a6 ecu if your going to convert. If your going to go the vtec route get the p28.
russianswty is offline   Reply With Quote
Old 11-27-2006, 04:46 PM   #9
ej2laosboi's Avatar
Rep Power: 0 ej2laosboi is on a distinguished road
alrite i been thinking about doing the swap too.. right now i have a 95 honda civic dx, and i also have a d16z6, i have all the vtec stuff to come with it but where can i find a p28 and how much would it cost to actually do the mini me swap? pm me
ej2laosboi is offline   Reply With Quote
Old 11-27-2006, 04:47 PM   #10
ej2laosboi's Avatar
ooh and is the mini me better than just a rebuilt d16z6? pm plz
Old 04-29-2007, 01:38 PM   #11
Rep Power: 0 TellMe7 is on a distinguished road
Originally Posted by Blanco View Post
P28s usually got for around $125 shipped. Look in classified ad's and on eBay. Don't pay more than this price for a virgin (unchipped) P28.
Better is a highly subjective term. You'll rev faster with the D15 block because of the shorter stroke but you'll also lose displacement and low end torque, but you'll have a slightly higher compression than a Z6 so it might even out. Personally, I'd just drop the Z6 longblock in.
After get the ecu do i have to get new wirer harness or any to put it on my d16a6???
TellMe7 is offline   Reply With Quote
Old 12-09-2008, 06:41 PM   #12
Rep Power: 0 sir honda is on a distinguished road
i want to as one thing i hav a d15b7 i want a vtec head wht head to go with or i should just swap the motor
sir honda is offline   Reply With Quote
Forum Jump
mini me d16z6 vtec head swap 127hp onlytime Parts: For Sale/Trade/Wanted 2 07-11-2004 07:12 PM
Engine Swaps 101 pissedoffsol Swap Articles 0 01-11-2004 06:54 PM
need help with mini me swap wiring StealthMode HYBRID -> EG-EK / DC 4 11-11-2003 04:16 PM
What's All Needed For Mini Me Swap? 92CivicLX HYBRID -> EG-EK / DC 0 04-21-2003 01:34 PM
Z6 Or Y8 Head On Mini Me Swap frawl420 HYBRID -> EG-EK / DC 8 04-12-2003 08:43 PM
SEO by vBSEO 3.2.0
 | a SkeyMedia Network site
