mini me wiring
Old 08-25-2008, 04:47 PM   #1
Ride:  89 honda crx si and 94 chevy s10 4x4
Rep Power: 12 sevenhillsbilly will become famous soon enoughsevenhillsbilly will become famous soon enough
Question mini me wiring
im one of the hundreds of people doing a mini me swap and was wondering is there any other way of wiring the vtec into the ecu besides getting a jumper harness from my a6 block to my z6 head?
sevenhillsbilly is offline   Reply With Quote
Old 08-25-2008, 04:48 PM   #2
and can you use the plug wires on the z6 head from my a6 head?
Old 08-26-2008, 12:36 PM   #3
well i am goin to get a tune after i hook it up and the p28 is the z6 ecu right ?
Old 08-26-2008, 12:45 PM   #4
so if i swap ecus it shoudl be ok
Old 08-26-2008, 07:19 PM   #5
ok and i would also need the z6 harness right or can i use my a6 harness with the jumper at the ecu?
Old 08-26-2008, 07:34 PM   #6
Honda Enthusiast
Luis998's Avatar
Ride:  '94 EG sedan w /Z6, '97 EK hatch
Rep Power: 103 Luis998 has a reputation beyond repute
Luis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond repute
I'm not sure I saw what year car you are doing your swap in. If it is 91 or before it is OBD0 and you will need an OBD0-OBD1 conversion harness. Check out www.rywire.com They will be able to help you out in getting your harness. Best of luck to you my friend.
Max? There is no max. Max just means you gave up.
This is my thread: http://hondaswap.com/engine-building...g-wind-110848/
http://hondaswap.com/members-lounge/...thread-278554/
Originally Posted by LS_VTEC View Post
lol... you could say that doing it right will "get you bitches". ;x
Originally Posted by efhondakid View Post
"Im so JDM I sleep on the right side of the bed"
Luis998 is offline   Reply With Quote
Old 08-26-2008, 09:43 PM   #7
what exactly would i have to do ? im a newb to the mini me i get the concept but the wiring is the hard part for me
Old 08-28-2008, 09:07 AM   #8
ok so i need a p28 the jumper and that would be it?
Old 09-01-2008, 01:28 PM   #9
i have a prob with the dizzy goin into the z6 head it wont go all the way in. it seems to go in on the bottom of the hole but not the top do i just force it in or is there something i can do?
Old 09-01-2008, 09:37 PM   #10
everything is lined up but for some reason the it goes inthe bottom of the hole better than the top i was goin to try and use a clamp to push it in but it wont go in right do you think it would be better just to go get the dizzy for the head
Old 09-01-2008, 09:51 PM   #11
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 227 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
It should go right in, but you should get a Z6 dizzy.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 09-04-2008, 04:59 PM   #12
another question would it be better if i bought a z6 harness or just keep the a6 harness and use a jumper for the head?
Old 09-04-2008, 05:14 PM   #13
so i need an obd0 to obd1 jumber, a z6 dizzy, a p28 ecu, and my original a6 harness to make this swap work correctly?
wiring for mini me swap dj30224 HYBRID -> ED-EF / DA 2 11-18-2006 10:32 AM
mini-me wiring problem chinslip HYBRID -> EG-EK / DC 1 01-08-2005 05:56 PM
Another wiring question? Mini-hybrid... ErikGG HYBRID -> EG-EK / DC 3 10-28-2004 03:31 PM
mini me v-tec wiring 4DRonDUBS ECU's, Electronics, and Tuning 0 05-27-2004 09:04 PM
need help with mini me swap wiring StealthMode HYBRID -> EG-EK / DC 4 11-11-2003 05:16 PM
