more fing problems with my swap
Old 05-29-2004, 08:56 PM   #1
my name is Dale
erebunicrx's Avatar
Ride:  cbr 929rr
Rep Power: 35 erebunicrx is an unknown quantity at this point
Send a message via AIM to erebunicrx
well, finally started the motor swap today and find out i have no rear engine bracket. i get one and find out that the bracket will not line up to the s1 tranny and the ls motor. is there a different bracket i schould use? im using hasport mounts.
03 mustang mach1, procharged, built motor, 6sp swap, built rear. 525whp @9psi
00 cbr 929rr 420 conversion -1 +2
erebunicrx is offline   Reply With Quote
Old 05-29-2004, 09:21 PM   #2
did you get it from a 90-93 Integra?
you are talkin about the rear engine bracket arent ya?
90 Integra Sedan
B20V 225 / 153
Old 05-29-2004, 09:30 PM   #3
my name is Dale
erebunicrx's Avatar
Ride:  cbr 929rr
yup and yes
Old 05-29-2004, 09:35 PM   #4
what car are we speakin about... if its an ED8/9 then you obviouslt arent doing somethig right.
are you 100% sure the bracket came from a 90-93 INTEGRA?
90 Integra Sedan
B20V 225 / 153
Old 05-29-2004, 09:39 PM   #5
my name is Dale
erebunicrx's Avatar
Ride:  cbr 929rr
the guy i got the bracket from said it was from a teg. are the years different for the brackets? its not a ls tranny but that schould not be a problem right? and yeah its a 91 crx si
Old 05-29-2004, 09:49 PM   #6
not an LS tranny, what is the trans from? This wouldnt matter as long as it a B series transmission.
Well either way it wouldnt matter - obviously you've been lied to. You need to look for another bracket... this time make sure its from a 90-93 INTEGRA.
90 Integra Sedan
B20V 225 / 153
Old 05-29-2004, 09:53 PM   #7
my name is Dale
erebunicrx's Avatar
Ride:  cbr 929rr
humm, he gave it to me and its real close just like a 1/2 in off, but enough to not get the bolt in the top hole.
Old 05-29-2004, 09:57 PM   #8
what did you tell him when you went to get it
90 Integra Sedan
B20V 225 / 153
Old 05-29-2004, 10:06 PM   #9
my name is Dale
erebunicrx's Avatar
Ride:  cbr 929rr
i did'nt tell him anything i called someone and he called someone and showed up with a bracket. i told the first guy i needed a integra rear engine bracket. is there any other motors with a rear bracket close to the same?
Old 05-29-2004, 10:24 PM   #10
listen to me you need the bracket from a 90-93 INTEGRA. I dont think the bracket of a 94+ integra will work. so call a junk yard and find the damn bracket it shouldnt cost more than $50. I in fact sold Ian (gsrcrxsi) one for $35. So there ya go, theres the answer to your quesiton.
90 Integra Sedan
B20V 225 / 153
Old 05-29-2004, 11:19 PM   #11
my name is Dale
erebunicrx's Avatar
Ride:  cbr 929rr
ok thanks
Old 05-30-2004, 02:42 AM   #12
Citizen_Insane's Avatar
Rep Power: 51 Citizen_Insane will become famous soon enough
Send a message via AIM to Citizen_Insane
I have one. PM sent
No tech questions through PM please!
B16 CRX....you will be missed
Citizen_Insane is offline   Reply With Quote
Old 05-30-2004, 02:44 AM   #13
awesome ktanaka...
90 Integra Sedan
B20V 225 / 153
