motor wont start
Old 05-27-2004, 10:03 PM   #1
Rep Power: 12 jbird is off the scale
i didnt know where to put this so if i put it in the wrong area im sorry. i have a 90 crx and i just put a b16 in it, i went to start it today and it wont start. i turn it over and it just stops. with out ever starting. if i turn the crank by hand it with crank for a second then stop again like the motor is frozen. please help.
jbird is offline   Reply With Quote
Old 05-28-2004, 03:07 AM   #2
I'll be back...
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 91 Civic DX
Rep Power: 156 B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
have you looked at the timing belt??? if it's broken, sounds to me like your running into valves...time for a new head...better yet, just get another motor...if i am correct that is
Real Eyes Realize Real Lies
B16RacerN2NR is offline   Reply With Quote
Old 05-28-2004, 09:11 AM   #3
i just put a new timing belt on it . i just pu t the motor in. this is the frist time i tried to start it.
Old 05-28-2004, 09:12 AM   #4
Old 05-28-2004, 09:13 AM   #5
Old 05-28-2004, 09:13 AM   #6
i just put a new timing belt on it . i just put the motor in. this is the frist time i tried to start it.
Old 05-28-2004, 09:14 AM   #7
Old 05-28-2004, 09:16 AM   #8
i just put this motor in and replaced the timing belt. this is the first time i have tried to start it.
Old 05-28-2004, 11:19 AM   #9
Rep Power: 15 typesiracing is off the scale
Send a message via AIM to typesiracing
have you tried to start it before???? lol j/k
are you sure you put the belt on right and checked all the timing marks?
I'm new to the game but learning quick....thanks for all the help guys!
94 Lude many mods (h23)
94 CX B18b
93 DX with '95 b18c ls/vtec
w/ type r pistons and crower valve train
97 Toyota Tacoma (to transport all my parts)
89 Nissan 240sx (someday project)
typesiracing is offline   Reply With Quote
Old 05-28-2004, 11:20 AM   #10
Rep Power: 12 Floydy is off the scale
Send a message via AIM to Floydy
Did you make sure that the timing is correct and not a couple teeth off?
Daily Driver- 88 Rex with ZC swap. (Soon to have an ls/vtec)
Floydy is offline   Reply With Quote
Old 05-28-2004, 12:00 PM   #11
the timing is right on and the motor turns freely by hand.
Old 05-28-2004, 01:59 PM   #12
well i got it to turn over now it wont start. this sucks
Old 05-28-2004, 03:58 PM   #13
Rep Power: 13 racingtopher is off the scale
is gas going to the injectors?
racingtopher is offline   Reply With Quote
Old 05-28-2004, 04:44 PM   #14
Citizen_Insane's Avatar
Rep Power: 51 Citizen_Insane will become famous soon enough
Send a message via AIM to Citizen_Insane
Check for spark.
Check for fuel: crank it over a few times then remove one of the sparkplugs and see if you can smell gas
Just keep crankin it! Mine wouldn't start for the longest time and you know what was wrong? NOTHING!!!! It just needed to be cranked over a few times. Most of these motors have been sitting on a lot for 5 yrs or more so give it some time. Now if it won't crank after like an hour of cranking, you have a definite problem.
No tech questions through PM please!
B16 CRX....you will be missed
Citizen_Insane is offline   Reply With Quote
Old 05-28-2004, 06:55 PM   #15
It might be your fuel pump. Use a volt meter to check if the fuel pump is getting power. If it is then the fuel is cashed. Also check the main fuel pump relay under the dash.
Old 05-28-2004, 07:21 PM   #16
it is getting fuel. im checking the spark now
Old 05-28-2004, 07:56 PM   #17
its alive! I finally got it running and it sounds great. thanks for all the help!
Old 05-29-2004, 04:51 PM   #18
Rep Power: 28 Bl6CRX is off the scale
Send a message via AIM to Bl6CRX Send a message via Yahoo to Bl6CRX
Bl6CRX is offline   Reply With Quote
