my gsr (JDM B18C) motor is almost completly ready to be swapped into my 90 civic si (hatch).
I have a Mount kit that apperently needs a post mount on the timing belt side from a 90 integra LS in order to work. I am having a hard time finding this part... are there any alternatives ? Any ideas would be mucho appreciated. thnx |
90-93 block mount brackets were the same...
![]() #8 11910-PR3-010 $41.69 you may also need to order #25 acutally i may have hte part, let me check I checked part numbers, both are same from 90-93.
90 Integra Sedan B20B - BROKEN LSVTEC - BROKEN PMTR - running strong! I DO NOT answer tech questions via PM. Use the forums!!! |
#5 |
you do need that L bracket also (sp? it doesnt look right)
89 EF build: Poorman's ITR 95 GSR bottom end, .25over b16 pistons Pr3 Zealautowerks compression = 11-8-1 ARP head studs, Stock head gasket S2 Pro series IM, w/ Hondata intake gasket Holley 68mm throttle body ITR 4-1 header, w/ 2.5 in magna flow exhaust ( sounds niceeeee btw) kteller 2.5 mandrel bend kit. PnP b16 head w/ dual valve springs and ITR cams Milled about .030 AEM hybrid CAI Running obd1 w/ p28 tuned on chrome Made 178 at churches w/ 2in exhaust and dc 4-2-1 header w/ 2 in collector. |
