Need help code 9 in my hf w/b16a
Old 01-02-2007, 10:58 PM   #1
xips(86CRXSI)'s Avatar
Ride:  91 si hb gsr swap
xips(86CRXSI) is off the scale
myspace
Default Need help code 9 in my hf w/b16a
Ok so I swap out just about everything from the wracked 90 ef hb civic to my 89 ef hb civic, I put the engine/trans/wiring harness(complete)/ecu/fuse box/axle's/and spindles.
The motor is a b16a and the problem I have is the cyp sensor is either not working or is not wired correctly, from what I can find is that the wire's go from the connector on the distributor to c1 and c2 on the ecu plug, I think that the wires are blue/yellow and blue/green. So I found them on the distributor and the ecu and thay were spliced into by someone already so I reran the wire's and I'm still getting the code. I'm not sure if that's the right way to connect the wire's or if its a mechanical problem. If anyone can tell me what to do that would be grate. Thanks.
PS The car won't start with the key and I have no dash lights, I ran a starter switch so I could start it but it would be nice to use the key and dash lights would be nice too, If someone can give me some pointers on those two thing's that would be appreciated, thanks.
xips(86CRXSI) is offline   Reply With Quote
Old 01-03-2007, 07:44 PM   #2
myspace
hello anyone?
Old 01-04-2007, 08:33 PM   #3
Andrew's Avatar
Ride:  1991 CRX Si
Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Have you checked the ignitor in the dizzy yet?
or maybe trying a different dizzy?
Old 01-05-2007, 04:24 AM   #4
myspace
by dizzy you mean distributor ?
what other dizzy will work for this? (B16A)
how would I check the ignitor ?
Thanks
Old 01-05-2007, 05:14 AM   #5
Andrew's Avatar
Ride:  1991 CRX Si
First off, use an obd-1 distributor(yes Dizzy), off of a D16Z6, that way your staying D series.
You check the ignitor by checking resistance through the terminals in it. Buy a Honda workshop manual and it'll walk you through it.
Old 01-06-2007, 03:03 PM   #6
myspace
I fixed the problem, the wires on the cyp sensor were not making a good connection so I used the pick up unit from the tdc sensor and used a tdc sensor from a dizzy that was on a 89 sohc non v-tec. no more code 9. now I just need to hook up the down pipe to my mid pipe and figure out the fans or wire them to turn on when the car turns on. O and my dash lights and a alinement needs to be fixed.
VAFC Controller bypass engine code? kylelohrenz ECU's, Electronics, and Tuning 3 12-06-2006 01:13 PM
P1457 code? hondadriver General Tech and Maintenance 8 09-27-2006 01:37 AM
Engines with the fastest piston speeds asmallsol Members' Lounge 10 08-25-2006 08:01 AM
P1457 code help hondadriver General Tech and Maintenance 7 06-11-2004 08:43 PM
codes civichbwithb18a1 HYBRID -> ED-EF / DA 1 10-03-2003 02:24 PM
