Need Obd1 Dizzy wiring help.
Old 08-09-2005, 06:53 AM   #1
5speed4life is off the scale
Send a message via AIM to 5speed4life
Ok, I am finishing up my wiring harness right now, and im working on the dizzy plugs. I converted the car to obd1 with a p28 and jumper harness. Im using the obd1 dizzy in this swap, and have it all wired up except for the solid white wires on the plug. There are two coming out of the harness, but only one on the dizzy. One is shielded along with the rest of the dizzy wires, and the other is not.
Witch one do i use, or do i use both? or does the other one go to a diffrent color wire (there are 2 or 3 other ones i was gona run straight to the ECU, that i have to add)
Spooning Leads to Forking 99% Of the Time.
Sig edited by moderator - No pics please
5speed4life is offline   Reply With Quote
Old 08-09-2005, 09:03 AM   #2
jlicrx's Avatar
jlicrx has a brilliant futurejlicrx has a brilliant futurejlicrx has a brilliant futurejlicrx has a brilliant futurejlicrx has a brilliant futurejlicrx has a brilliant futurejlicrx has a brilliant futurejlicrx has a brilliant futurejlicrx has a brilliant future
Engine Harness-----------------OBD1 Distributor
Orange-----------------------------White
White/Blue-------------------------White/Blue
Blue/Yellow------------------------Blue/Yellow
Thin White-------------------------Orange
Orange/Blue-----------------------Orange/Blue
Blue/Green-------------------------Blue
Fat White---------------------------Yellow/Green
Old 07-15-2006, 08:12 AM   #3
IOU1 is an unknown quantity at this point
Would this wiring be the same for an OBD2B one plug to a 92-95 JDM B16A 2 Plug? Or how can it be done?
IOU1 is offline   Reply With Quote
