need swap info
Old 02-15-2005, 12:33 AM   #1
Rep Power: 0 90tegls is off the scale
have a 90 teg ls what to do swap but not sure on what the best swap asking for help? if i do a ls swap would i need to use the obd1 computer and harness or i could use my obd0 ecu and do a plug n play (piggieback) or if i do any swap at all do i need to change my ecu . again wit the swap question i want to be all motor so what the best internal work . thankx alot for the knowledge you can pass on to me.
90tegls is offline   Reply With Quote
Old 02-15-2005, 01:38 AM   #2
Blah blah blah....
MikeBergy's Avatar
Rep Power: 49 MikeBergy is on a distinguished road
Send a message via AIM to MikeBergy
The best option you have IMO is to build the negine you already have. The LS is a potent candidate, just begging for a little head work and some bottom end strength. The block is a good base for a decent amount of torque. I know right now that there are going to be people that tell you LS/Vtec is the best, and if you have the money, go for it, but the motor is good as is for a mild turbo setup. I am going all motor as well, talk to rocket at RM forums about hooking you up with some go fast goodies. If you want max power and streetable idle without considering cost, Ls/vtec's probably your best bet. My suggestion is that you read up on some of the things that people have already done to the DA chassis (90-93 integra) on Gen 2 Integra Club; that will give you a good idea about what can be done. Good luck man! I have a 91 integra, so if you need any tips on the car just ask.
-1991 Integra, lots of goodies in an otherwise stock looking motorp; ITR front brakes.
-Xenocron programmable ecu w/datalogging port, LM-1 wideband, and Moates Ostrich are tuning tools of choice.
RIP 2005 Red Yamaha R6
www.m24x.com - Rocket Motorsports: For more technical engine discussions...
Radar will bounce off of a ride that is shiny and you keep clean.
Please don't PM me with tech questions. Use the forums!
MikeBergy is offline   Reply With Quote
Old 02-15-2005, 11:28 AM   #3
Rep Power: 19 racintweek is an unknown quantity at this point
one of the cheapest hp/$$ options is boost, if you have money to spend there is a good deal of power that is suffocated by your cams and head
"sometimes you just have to race"
-Dave Chappelle in D.C.
<div class=\'quotetop\'>QUOTE</div><div class=\'quotemain\'> if one car has more torque and another more power, the one with more power will actually end up having more torque at the wheels</div>-Honda-Tech user
racintweek is offline   Reply With Quote
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
