new here... have abig problem
Old 02-22-2004, 07:27 PM   #1
Rep Power: 12 4gcivicY8 is off the scale
Send a message via AIM to 4gcivicY8 Send a message via Yahoo to 4gcivicY8
yo i'm new here . anyway i need help i have a d16y8 in my car now and i need help wiring it up . heres some problems . i have a dpfi to mpfi wiring harness from hasport heres my questions . on the harness there a connector that connets to a coolet senors in the back of the block . but i can't find it on the Y8. next the distributor has a bigger connector then on the harness should i try to wire it or buy a a6 distributor. and i think thats it for right now thanks. if you guys have any links to any sites that have done this swap befor that would be cool to thanks
4gcivicY8 is offline   Reply With Quote
Old 02-23-2004, 10:59 AM   #2
Rep Power: 15 Drenni is off the scale
I'm lost could you try and explain with a little more detail, cause if you are doing the DPFI to MPFI you to buy a distributor for a SI or atleast I did the DX or LX one won't work with that set up. I hope or think that's what you're asking.
"If you only knew the power of the dark side of the Honda"
Drenni is offline   Reply With Quote
Old 02-23-2004, 01:25 PM   #3
Rep Power: 19 radnulb is on a distinguished road
Send a message via ICQ to radnulb Send a message via AIM to radnulb
simple solution: get a D16A6 distributor and PM6 ECU
harder solution: convert to OBD1 + get P28 ECU.
PGMFI.org founder and DIY ECU tuning advocate
Just say no to rice...
radnulb is offline   Reply With Quote
Old 02-23-2004, 09:04 PM   #4
sorry for all the confusions. 1. the distibutor was an si the hasport wiring harness is for a dpfi to mpfi on the dx and it still retains the 1.5l dis. 2. i was talkin about the 2 prong oil sending unit in the back of the block on stds and dx's. the y8 has no unit thats two prong on the back of the block . there is however a bolt where it looks like one should be. should i 1. take the bolt out and put the 1.5 unit in or find out where to wire it. again sorry for the confusion . thanks
Old 02-24-2004, 10:55 AM   #5
Rep Power: 15 hammerdgolfer is off the scale
i have some si a6 stuff sitting in my garage since i never did the dpfi conversion and now going b series,
keep checking everywhere under the intake manifold and everything for what your looking for, it may be hard
hammerdgolfer is offline   Reply With Quote
Old 02-24-2004, 08:13 PM   #6
well i donno about teh distrubutor . but the coolent temp unit was rewired to the ya coolent sensor i no i'm an idoit i should have known
Old 02-25-2004, 06:45 PM   #7
new problem i need a y8 and a d15 vacuum diagram if anyone knows where i can find there it would be real cool
Wiring Problem delslow ECU's, Electronics, and Tuning 2 07-18-2004 01:21 PM
Electrical Problem With My 1986 CRX Si The_MATRIX General Tech and Maintenance 0 06-17-2004 06:08 PM
Prelude 1997 Heat problem... ovcrash General Tech and Maintenance 2 03-12-2004 11:45 AM
i need help!! suspension problem littlehatch Wheels / Suspension / Tires / Brakes 1 12-07-2003 04:58 AM
Vetc problem Mr.Steve HYBRID -> ED-EF / DA 2 08-07-2003 11:51 PM
