Facebook Twitter
Not Reving High enough?
This is a discussion on Not Reving High enough? in the HYBRID -> ED-EF / DA forum
I got a 88 zc in a 90 civic. The ECU is the pm7 from an 89 teg. The distributor is from a 89 teg. The one with the j-spec engine was shot. My car cuts at 7100rpm, sometime lower. I have a cheap tach ...
Old 06-30-2003, 07:01 PM   #1
I got a 88 zc in a 90 civic. The ECU is the pm7 from an 89 teg. The distributor is from a 89 teg. The one with the j-spec engine was shot. My car cuts at 7100rpm, sometime lower. I have a cheap tach so I bought an autometer and it read the same thing. Why wont my car go to 7800 like it should. It's a big jolt when you think you can go higher but then the engine cuts. The zc dist didn't have an ignition capasitor but the 89 teg does, will this effect it? I want those extra 700-900 rpms!!!!!!
"The only replacement for displacement is technology!!!!!"
90 Civic DX
Coilovers with Adj Struts
HMT 14b Turbo
Audi FMIC
DOHC 2.25 full exhaust
Short Shift DIY Tuned ECU
90vtec is offline   Reply With Quote
Old 07-01-2003, 09:18 AM   #2
I do believe he PM7 fuel shut off is around 7200, so either get a ZC ECU, or a chip[ped PM6, or deal with it.
gohondago is offline   Reply With Quote
Old 07-02-2003, 09:56 AM   #3
, Mine goes at 7200 rpms unless you chip it it not supposed to go any higher that's what I think.
Drenni is offline   Reply With Quote
Old 07-02-2003, 09:57 AM   #4
Maybe if you got a PG7 and that's for a teg, it should go higher, but then again I'm not sure sorry
Old 07-02-2003, 10:16 AM   #5
pretty simple actually. The teg ecu limits at 7100. Chip it with just a rev limit remover. *edited* for mis-info
liquid00meth is offline   Reply With Quote
Old 07-02-2003, 11:04 AM   #6
liquid00meth, the ecu he is using is from a 88-89 integra. it has the same displacement as the zc, or 1.6 liters. he is not using an ecu with a different displacement than the engine he has. this ecu is commonly used because it is better than a si ecu and much easier to acquire than a zc ecu.
allmotord16rex is offline   Reply With Quote
Old 07-02-2003, 11:20 AM   #7
hmm I thought the ls engine was larger. my bad. In any case, the rev limit is still different on the two motors.
Thanks for the correction.
Old 07-13-2003, 08:16 PM   #8
Alls good guys. The PG7 teg ecu cuts at 7800. the pm7 zc ecu at 7500. but the pg7 has a cold cut at 6800. so until my engine warms thats were it cuts. now she goes to 7600 rpm and i write the missing 200rpm of at the cost of the cheap tach!!!
research paper, what do you think? 90 accord Members' Lounge 9 06-22-2004 11:11 PM
High Flow or High Pressure? turbo4dr Forced Induction 7 03-23-2004 05:47 AM
High Idle Than Bam Irratic Idle Accordturbo94 General Tech and Maintenance 39 11-07-2003 11:22 PM
high c/r with turbo civicious Forced Induction 9 10-20-2003 12:35 PM
High Compression & Nitrous michaelgomez Forced Induction 1 06-06-2003 01:57 PM
© 2001-2013 HondaSwap.com
