OBD 1 Engine harness?
Old 05-24-2004, 01:15 PM   #1
Rep Power: 13 racingtopher is off the scale
Can you use the B16 OBD 1 engine harness (the onee that came with my B16) in an OBD 0 civic?
Can you just plug the big round connector into the original plug that goes into the car?
If so, how or where can i find wire diagrams and instructions how?
Thank you.
racingtopher is offline   Reply With Quote
Old 05-24-2004, 02:17 PM   #2
Rep Power: 13 dreded90crxsi is off the scale
Send a message via Yahoo to dreded90crxsi
I asked this same question once and from what I was told it will not work with out lots of modification to the wiring. I think it's something with the connectors on the harness not hooking together or something like that. Hopefully someone else will reply to this and be able to explain it better.
Life is a race, what place are you in?
dreded90crxsi is offline   Reply With Quote
Old 05-24-2004, 09:48 PM   #3
Rep Power: 14 blngblngskater is off the scale
check the obd0 to obd1 post in this same forum
blngblngskater is offline   Reply With Quote
Old 05-24-2004, 11:33 PM   #4
Rep Power: 23 cycloneb18c3 is off the scale
Send a message via AIM to cycloneb18c3
No it wont work....
the stuff below has to be 0bd-0 to work
distributer
injectors
alternator
engine wiring harness
then u have to wire vtec which is:
vtec solenoid
vtec oil pressure sensor
2nd o2 sensor
knock sensor
and depending on weather ur civic is DPFI, then u have to wire it up for 4 injectors, and some other stuff.
heres a link to a page that will help you with wiring into the ecu(thanks to katman!)
obd-0 ecu wiring picture
hope this helps
Dan
whoever said nothing is impossible, never tried slamming a revolving door
cycloneb18c3 is offline   Reply With Quote
Old 05-25-2004, 06:35 PM   #5
my engine is already obd-1 and is using the d16a6 obd-0 engine harness that then connects to a obd-1 ecu. all i added was the vtec wires to the harness.
i just want to try use the b16 harness because it will fit better around the engine.
