EF Tuner
Ride: 89 Si hatch, b18a swap. 98 GS integra
trying to narrow down what could throw this code. i know this code is for the fuel system, but what part of it am i looking to find a problem...motor needs rebuilt( rings, headgasket). runs great! after it warms up, it throws this code and cel comes on...this is the ONLY code it will throw, and it seems to be running a tad rich. any help will be greatly appreciated...thanks in advance...__________________
Please send me rep points if I am helpful..... 98 integra GS--> Daily 89 Si hatch--> project 92 CX hatch--> wife's daily |
i lOve my Ef sedaN..
Ride: 1998 ef 4door
i think u mean ( 4 blinks then 3 blink ) 4-3
obd1 will trow ( 4long blinks the 3 fast blinks) 43 4 CKP - crank position sensor ( dizzy problem ) & 3 MAP - manifold absolute pressure sensor ![]() |
#3 | |
EF Tuner
#6 |
im sure we both are talking about a code 43, fuel delivery system not a map or dizzy problem.
our cars are running fine, we are just using too much fuel. as shown on my smog results. so far what i have done; changed all the vacuum lines, adjusted the timing, checked the fuel pressure regulator, i even changed the injectors to 91 si and the code still lives bright. my o2 sensor is brand new, new oil, filters s.plugs, wires, cap rotor to insure the ignition system is in working order. i will check the fuel pressure tomorrow, need to buy the tool. might be the fuel cut off solinoid or something stupid. anybody else delt with this and found the solution? |
| Tags |
| fuel system, integra, obd0, obdo |
| Code 2, Oxygen Sensor on PW0 OBD0 | Mattyg2 | HYBRID -> ED-EF / DA | 5 | 07-20-2008 10:24 AM |
| Throwing Code 14 EACV Obd0 PR4 | crxsir3 | Civic and CRX - EF | 1 | 03-29-2008 11:47 PM |
| FS: Obd0 B16 Swap Complete EF Swap Mounts, linkage,ecu Cheap | Mr.slippyfist | Parts: For Sale/Trade/Wanted | 10 | 09-06-2006 09:20 PM |
| Obd0 to obd1 code 22 wiring help! | jtracerx69 | ECU's, Electronics, and Tuning | 1 | 09-04-2005 09:31 PM |
| Significant update to OBD0 / TurboEdit Code | radnulb | ECU's, Electronics, and Tuning | 4 | 03-01-2005 04:52 PM |
