| | LinkBack | Thread Tools |
| | #1 |
| Junior Member | i'm doing an obd1 LS swap into my crx, and i found on the obd1 harness there is a brown plug that plugs into the thermostat housing that the obd0 crx harness doesn't have... the d16 doesn't have the sensor on the thermostat housing. do i have to extend the wires and run it to the ECU, or is there another option? i can take pics if no one knows what i'm talking about... thanks in advance |
| | #2 |
| FüK-VTEC | On the OBD0 motors, the fan switch is on the back of the block close to the oil filter; it's a 2-wire plug that has 2 individual prongs on it. You'll need to get a plug from another harness that will plug into the switch on the thermostat housing, extend the wires on the OBD0 harness, and wire these 2 wires to the plug. Then plug that into the switch on the OBD1 thermostat housing. |
| | #3 |
| Junior Member | thanks civicious.. on the LS block there's still a sensor next to the oil filter, it has blue/yellow & yellow/black wires coming from a green plug, what do i do with that one? on the obd1 harness there is 3 of the 2 prong plugs you mentioned, i know one goes on the thermostat housing and the other goes underneath the distributor, i just dont know what to do with the one for the back of the block. |
| | #4 |
| Junior Member | the plug on the back of the LS block is green, with a white/green and black wire coming from it.. what do i splice it to on the crx harness? the only thing left is a plug that has a blue/yellow and brown wire.. |
| OBD1 B18A1 wiring in 89 CRX Si | JoeLouie | HYBRID -> ED-EF / DA | 6 | 12-06-2008 08:20 AM |
| OBD0 to OBD1 dizzy sub harness wiring | arf4n | HYBRID -> EG-EK / DC | 1 | 04-28-2007 11:19 AM |
| newb wiring question | truamw315 | HYBRID -> EG-EK / DC | 0 | 08-30-2006 09:52 PM |
| obd1 dohc zc in obd0 crx help!!! | lil_red_rex | HYBRID -> ED-EF / DA | 8 | 08-12-2006 10:02 AM |
| obd1 b-series wiring guide | pissedoffsol | Swap Articles | 0 | 01-12-2004 01:09 AM |
