obd0 zc cable tranny onto obd1 sohc vtec d15b engine?
Old 07-03-2009, 11:02 PM   #1
SOHC VTEC at its best
95EGCoupeVtec's Avatar
Ride:  95 Civic EX Coupe
Rep Power: 6 95EGCoupeVtec will become famous soon enough
myspace
Default obd0 zc cable tranny onto obd1 sohc vtec d15b engine?
title says it all. my brother in law is going to get a obd1 d15b and i need to know if the sohc zc cable tranny will hook to it. OR is there anyway to get from cable clutch to actuate a hydro tranny. thanks
95 Civic EX Coupe:
GSR suspension
rear LCAs & tie bar
no PS or A/C
Turbonetics t3/t4B (ceramic ball bearing) Super V Trim, Stg 2 .48 A/R
Xenocron chipped ecu
Greddy Type RS bov
Tial 38mm WG
GOAUTOWORKS cast mani, 3" DP, WG dump, & oil lines
Spearco Intercooler
450cc DSM blue tops
walbro 255
HG and ARP studs
Aluminum rad/fan combo from GoAutoworks
Competition Clutch Stg5 w/4puck disk
BF Goodrich Drag Radials
Soon to have:
15" Rota Slipstreams
tune by Darren in Baton Rouge, LA
95EGCoupeVtec is offline   Reply With Quote
Old 07-04-2009, 02:46 PM   #2
jlicrx's Avatar
what year and model car is this in? what engine is the D15B replacing? is this a ZC L3 transmission, with intermediate shaft and equal length axles?
typically, the 88-91 L3 cable clutch transmission will bolt right up to any of the 88 and up SOHC D-series engines - just need to make sure that the clutch matches the transmission - the ZC transmission which uses the intermediate shaft and equal length axles doesn't work with the D15B, as there is no place to bolt the intermediate shaft to the block
ZCspeed Racing
Old 07-05-2009, 12:30 AM   #3
myspace
its a 90 dx hatch. i didn't know that there was different zc trannies that had equal and unequal axles. the tranny is whatever one that H Motors Online would sell. probably the one with equal length axles. they said that it wouldn't work and that we would need to find a crx si transmission out of a junkyard to go with it that they didn't sell the proper cable tranny to work with that engine.
95 Civic EX Coupe:
GSR suspension
rear LCAs & tie bar
no PS or A/C
Greddy Type RS bov
Tial 38mm WG
Spearco Intercooler
450cc DSM blue tops
walbro 255
HG and ARP studs
Soon to have:
Old 07-06-2009, 09:47 PM   #4
myspace
do u know if you can use the unequal axles in the zc transmission? bc the zc wouldn't come with axles anyway.
95 Civic EX Coupe:
GSR suspension
rear LCAs & tie bar
no PS or A/C
Greddy Type RS bov
Tial 38mm WG
Spearco Intercooler
450cc DSM blue tops
walbro 255
HG and ARP studs
Soon to have:
Civic JDM D15B SOHC Vtec OBD1 92-95 Engine P08 ECU RSS-Bot Auctions 0 06-16-2009 02:03 PM
Jdm honda civic 1.5l d15b vtec sohc obd1 motor engine RSS-Bot Auctions 0 10-30-2008 05:50 PM
Jdm honda d15b sohc vtec motor 92-95 engine & tranny RSS-Bot Auctions 0 10-23-2008 03:03 AM
Jdm honda d15b sohc vtec motor 92-95 engine & tranny RSS-Bot Auctions 0 10-07-2008 02:36 AM
OBD1 or OBD0, Hydro or cable tranny? friz HYBRID -> ED-EF / DA 7 04-17-2008 03:27 PM
