Got a new engine and it ran fine but a week later is tryed it agian. The head had a little more noize than usual. and a few minutes later also my check oil indicator lights up. This engine has an new oil filter and new oil. I suspect that the head isnt getting enough oil or something. What to do or check next.
==Bye SI Hello DOHC.== |
did you put enough oil? did you let it warm a bit to see if it would go away? I always run a good engine cleaner through my engine about 3 days before i do an oil change just to make sure theres nothing clogged up in the passageways, try cleaning it out and changing the oil again, its probably your cheapest bet.
2001 Civic EX 2dr, shes beautiful, soon to be turbo. 1991 Crx dx Ls MONSTER BUILD ys1 trans its a beast. |
#3 | |
TTIWWOP
Ride: 1990 sohc vtec-t hatch, 1994 Bagged S10, 1991 Lifted Mazda
and check oil = low oil pressure could be a few things one, make sure oil didn't leak out from lets say a bad seal between block and filter 2, not likely, but sometimes the valves inside the filter can be bad and not allow proper oil flow your oil pump could be bad, or the pickup tube could be clogged... or your presser sending unit isn;t working right but if you heard a lot of valve noiZe(wtf mate?) then i would say its probably starving for oil and NOT the sending unit.. easiest thing to check is check the oil, and if its still full then change the filter, if that doesn't fix it then most likely you need to drop the oil pan and see what you can see.... oh, and DO NOT RUN THE CAR WITHOUT PROPER OIL PRESSURE... |
#6 |
FWIW, that oil light comes in with like ~4 PSI of pressure....not nearly enough to keep metal to metal contact from happening in the bottom end...DON't drive it or run it until you figure out the problem like everyone else has said!!
Friends Don't Let Friends Apex Early |
#7 | ||
The engine didn't run for a week.
