p06 ecm what car is it from
Old 05-25-2006, 11:08 PM   #1
Rep Power: 10 1996cool is an unknown quantity at this point
i have a p06 ecm and im just curious if itll run on a 92 -95 vtec engine, and also will the wires match up. and what car is it from ,any answer appreciate it
1996cool is offline   Reply With Quote
Old 05-26-2006, 12:22 PM   #2
jlicrx's Avatar
P06 is from 92-95 Civic DX and, no, it will not run a VTEC engine - 92-95 Civic had 2 VTEC engines - one in the VX D15Z1 which used P07 ECU and one in the EX D16Z6 which used P28 ECU
ZCspeed Racing
Old 05-26-2006, 08:33 PM   #3
<div class='quotetop'>QUOTE(jlicrx @ May 26 2006, 12:22 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
thank u very much.......what about the wiring will it be the same . for example pin # 123 and 5 are for injectors correct, etc..... and #4 is the vtec solenoid valve, right? i just want to make sure because im rewiring my car and i dont want to burn up my p28 ecu , brn,yellow,red,andlight blue for the color code. any help appreciated
Old 05-30-2006, 01:49 AM   #4
CrazyAzn's Avatar
Rep Power: 17 CrazyAzn is off the scale
u can change the board so it can throw vtec, but its kinda alot of work. . . but doable check out pgmfi.org. . . or something along those lines.
89 EF build: Poorman's ITR
95 GSR bottom end, .25over b16 pistons Pr3
Zealautowerks compression = 11-8-1
ARP head studs, Stock head gasket
S2 Pro series IM, w/ Hondata intake gasket
Holley 68mm throttle body
ITR 4-1 header, w/ 2.5 in magna flow exhaust ( sounds niceeeee btw)
kteller 2.5 mandrel bend kit.
PnP b16 head w/ dual valve springs and ITR cams
Milled about .030
AEM hybrid CAI
Running obd1 w/ p28 tuned on chrome
Made 178 at churches w/ 2in exhaust and dc 4-2-1 header w/ 2 in collector.
CrazyAzn is offline   Reply With Quote
