Problem wiring b16 in 89 civic hb dx
Old 02-19-2004, 05:28 AM   #1
Rep Power: 12 Tokay is off the scale
Unhappy
I bought a 89 civic si internal harness and a 91 teg LS harnes to fab what I need to but I don't exactly have all the answers on what I have to change. Tell me if I'm on the right track or if I was mistaken.
Also I need to know if I can use the injector plug that comes through the fire wall off the from the Si harness and run that to the injector portion of the teg LS harness. If so do I run it through the resistor box that comes on the teg or what. If that is necessary at all let me know. Kinda new too this stuff but trying to learn. Any help or links to instructions on these wiring challenges would be helpful. thanks
Parts I have :89 civic hb dx
B16a motor tranny & ecu (pr3)
91 TEG LS shift linkage
91 TEG LS axles
91 Civic hb SI harness
91 TEG LS Harness
Tokay is offline   Reply With Quote
Old 02-20-2004, 01:45 AM   #2
Rep Power: 15 hammerdgolfer is off the scale
parts you need:
civic si resistor box(88-91)
b series shift linkage for 88-91( i h ave some hasport for sale)
b series motor mounts for 88-91
hasport wire adapter(75 bucks) or you can home make a harness to add the 3 wires you need for vtec and stuff)
hammerdgolfer is offline   Reply With Quote
Old 02-20-2004, 12:54 PM   #3
jlicrx's Avatar
you need to use your DX engine harness and make the wiring changes to it - harnesses are not interchangeable - here is a good guide for the wiring
http://www.fourthgenhatch.com/mpfi.html
ZCspeed Racing
Old 02-20-2004, 06:27 PM   #4
Thanks I checked out the link. It seems to have every thing I needed. I ment to tell you guys the reason I have the LS teg harness is for the injector plugs. They fit the B16a. And I'm going to use the SI wiring and the SI Resistor box to add onto my DX loom to keep the color code continuity.
Question though: Where is the directions to the harness that runs the three or four wires for V-Tec and all that. I could buy it but I want to do the hands on work instead. And thanks for the helpguys.
Old 02-21-2004, 10:01 AM   #5
jlicrx's Avatar
2nd O2 Sensor - ECU pin C8 - red/blue
VTEC solenoid - ECU pin A8 - grn/wht
VTEC Pressure Switch - ECU pin B5 - blu/black
Knock Sensor - ECU pin B19
ZCspeed Racing
Old 02-25-2004, 07:10 PM   #6
Rep Power: 0 dandutka is off the scale
91 TEG LS axles
91 TEG LS Harness
I'm doing the swap as well on my dx and i have the wiring "problem" as well.. but should i go to hasport and buy the conversion kit... i keep my stock loom and then use the conversion.. its 249.99 or would it be cheaper ... to do it myself... Much harder?? as well ..is this all the wiring needed for the swap... (modification) ??
email me at v8hunter03@hotmail.com ...with any tips you would like to share about the swap for i'm doing it myself and have no idea where to start.... lol.. engienc omes oout tommorrow.. starting at 8 am
can;t wait
dandutka is offline   Reply With Quote
98 Civic "HX" B18B1 LS wiring problem Sil VurFoX HYBRID -> EG-EK / DC 6 06-30-2004 12:23 AM
Idle problem related to ECU wiring? turbo99 ECU's, Electronics, and Tuning 1 03-27-2004 05:33 PM
B16 sirII into 92 cx civic hb Gooseguir HYBRID -> EG-EK / DC 13 10-27-2003 04:28 PM
wiring issue on b16 civicious HYBRID -> EG-EK / DC 7 09-05-2003 04:33 PM
d16z6 in a 91 civic wiring problems!!!?! 89honda90 ECU's, Electronics, and Tuning 7 08-10-2003 06:22 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
