| | LinkBack | Thread Tools |
| | #1 |
| goldgeen90ef Join Date: Aug 2006 Location: cold ohio
iTrader: 0 / 0% Ride: 96 civic cx ,95 celica battle daily grinder, chuck taylors
Rep Power: 17 | my 91 crx si with a b16 has a cel for 02 sensor(it has the jdm xsi ecu) come on once in while. i looked under the car at the sensor, and they have 2 wires twisted togather going into the o2(im assuming for the 2 sensors the ecu is looking for? )how do i get around this ? drill the header for another o2 ? thanks |
| | #3 |
Rep Power: 17 | cool were should the 2nd o2 bung go? is it after the cat, in the cat, or right after the cat? thanks |
| | #7 |
| I'll be back... Join Date: Feb 2003 Location: Rancho Cucamonga - UTI Age: 26
iTrader: 3 / 100% Ride: 96 DB8, 06 Mazda 5
Rep Power: 174 | you need to have 1 o2 sensor for each cylinder pair. You can put another o2 sensor at the collector and the car will seem likes it's running normal but it's actually not... here's why... Tech - Closed Loop scroll down to where it says "Pre obd-1 engines" |
| | #8 |
Rep Power: 17 | thanks for the info guys!!! in your opinion, should i look at having the ecu chipped, or add a 2nd 02 sensor? thanks again also b16Racern2NR, a quick quest., so the former owner putting both the sensors input into one sensor is probely robbing some power? thanks again, and nice link Last edited by goldgreen90ef; 03-25-2007 at 08:17 AM. |
| | #9 |
Rep Power: 174 | yeah it definately is. It might not be noticeable, but it is. The best thing to do is buy the HaSport header but if you decide to chip your ecu, make sure the chip runs the stock map with just the 2nd o2 not being looked for unless you can get your car on a dyno and get a chip tuned specifically for your motor. |
| TONS of parts for sale B16, GSR, Type R | Envy_Motorsports | Parts: For Sale/Trade/Wanted | 28 | 02-08-2010 09:43 AM |
| b16 crx problems | dvj-crx | General Tech and Maintenance | 2 | 06-09-2006 10:34 PM |
| b16 sir-ii dizzy problems | 1995EGGuy | General Tech and Maintenance | 2 | 05-24-2006 04:31 PM |
| problems w/ 88 to 91 civic with b16 oem intake | flexers | General Tech and Maintenance | 1 | 05-12-2006 01:51 PM |
| B16 Running Problems | possessed imports | Engine Building | 12 | 06-02-2003 03:38 PM |
