Question concerning VTec solenoid
Old 06-29-2003, 05:50 PM   #1
Rep Power: 14 Raggedyman is off the scale
Quick question..........just finished wiring my swap and ran it without the VTec solenoid wired in....she ran great! But when I added the VTec solenoid (positive signal) it would hit the setpoint and just bog down. I'm using a 5" Autometer monster tach and using the shift light signal to initiate the solenoid for the VTec. Is this normal or do I have the timing off just a hair? I had the setpoint for 4200rpm but the tach doesn't show just right and I think it needs calibrating. Idling it hits around 1100. Am I just set too low since the tach is off by a hair?
Thanks for the input!
Keep the faith!
Raggedyman is offline   Reply With Quote
Old 06-29-2003, 09:23 PM   #2
nm......just figured it out.....dang that vtec does make a _slight_ difference when it kicks in. No wonder everyone likes those DOHC VTec's so much.....
Vtec Solenoid Troubles RandomTask76 HYBRID -> EG-EK / DC 5 05-20-2009 01:05 AM
FS DOHC VTEC solenoid toyz51 Parts: For Sale/Trade/Wanted 0 01-11-2004 11:01 PM
Can the VTec solenoid stick open/closed? Raggedyman General Tech and Maintenance 10 07-08-2003 07:07 PM
Cel Code 21 Vtec Solenoid Hybrid93Hatch ECU's, Electronics, and Tuning 0 04-21-2003 11:04 AM
