quick hood clearance question...
Old 03-16-2005, 11:31 AM   #1
Rep Power: 13 sleeper_crx88 is off the scale
im wondering about what hood to buy for my crx w/ gsr swap...i chopped some of the webbing out on my stock hood so now my hood closes but it still rubs a bit and if i could get a new hood that will clear the motor completly then i will. problem is i dont know which hood nor do i know where to find it. someone told me that i shoul get a jdm hood, but which one??? thanks for taking the time to read this...
sleeper_crx88 is offline   Reply With Quote
Old 03-16-2005, 11:45 AM   #2
Rep Power: 19 racintweek is an unknown quantity at this point
i have an LS in my hatch and the hood is fine, before you go spend $$$ on a diff hood see if using washers to lower the engine a little helps, if not, get a ZC hood
edit: english>me
"sometimes you just have to race"
-Dave Chappelle in D.C.
<div class=\'quotetop\'>QUOTE</div><div class=\'quotemain\'> if one car has more torque and another more power, the one with more power will actually end up having more torque at the wheels</div>-Honda-Tech user
racintweek is offline   Reply With Quote
Old 03-16-2005, 11:49 AM   #3
Rep Power: 22 PhyRe is an unknown quantity at this point
Send a message via AIM to PhyRe Send a message via Yahoo to PhyRe
what mounts. we have the hasport in a 91 si and we cant close the hood at all. we were told that any aftermarket cf hood will fit just not the oem oneso you might wanna look in to that.
if that can be done id try that too.
who asked you?
Big displacement motors are like tampons.....every pussy needs one
sir I w/ 00 head/itr intake + s1=$900
full d series turbo kit(turbo pistons rods pipes bov fmic oil pan) $1100
PhyRe is offline   Reply With Quote
Old 03-16-2005, 11:54 AM   #4
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
my hood closes with my lsv...but my engine sits lower in the bay....so i would get the hood and not drop the motor further into the bay....
http://pandora.com/
Old 03-16-2005, 01:27 PM   #5
Citizen_Insane's Avatar
Rep Power: 51 Citizen_Insane will become famous soon enough
Send a message via AIM to Citizen_Insane
With the hasport mounts you need to cut some of the support metal from the inside of the hood to make it fit. However, you shouldn't need a new hood to make it fit.
No tech questions through PM please!
B16 CRX....you will be missed
Citizen_Insane is offline   Reply With Quote
