Rex's D16y8 Build
Old 10-27-2009, 02:39 PM   #1
D-Series Ninja
riceracerex's Avatar
Ride:  90' Honda CRX Si
Rep Power: 11 riceracerex is a jewel in the roughriceracerex is a jewel in the roughriceracerex is a jewel in the roughriceracerex is a jewel in the rough
myspace
Lightbulb Rex's D16y8 Build
I figured it was time to open a thread with my Crx and document the steps I will be taking with my D16y8 so I can backtrack if anything goes wrong in the future. I will be posting a few pictures today and later on in the week of the y8 and my plans for the swap. I am running a D16a6 in my Si right now and will continue using it as a DD untill my y8 is a complete engine.
I do have questions, considering it is an OBDII engine I would like to make sure I have everything needed for the build before I swap. I already have a chipped PM6 using Turbo Edit and I am trying to find a OBD0 base map to go off of. Any ideas or do I just run the D16a6 map and wire the vtec? Also will I be changing injectors, Intake Mani, or the Dizzy to keep my OBD0? Just a few questions for now to get me started in the right drection. I know there are numerous threads for this swap but I have not found a good one with all the details yet. I guess this will be one by the time I am finished.
riceracerex is offline   Reply With Quote
Old 10-27-2009, 11:11 PM   #2
D-Series Ninja
myspace
Bumping with some new images of the build, the block was spray painted black when I got it. bleh yuck, I want a clean build!
The Block:
Crank:
Cylinders:
It had a little rust here and there and there was a big blob of blue rvt beside the oil filter adapter but besides that it's in fairly good condition. I will be using income tax to finish the build with a vitara turbo setup. Any suggestions would be appreciated. I don't really have a goal because I do not want to be disappointed and I do not expect a lot out of a D-Series but if I can hit the 300hp mark I will be very pleased. Thanks Honda Swap...
Old 10-28-2009, 01:44 AM   #3
Christmas Car
Ride:  93 4dr D15B, Greddy Short Ram, 4-2-1 Header, 2.5" Exhaust.
Rep Power: 8 RoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura about
300 outta the D...
good luck man
Please direct your questions in the following format.
1) Did I search it on Google?
2) Did I use the search function in the TOP RIGHT AREA of this page?
3) Refer to Step 1 and 2.
If that doesn't work, then feel free to post.
RoughKnight is offline   Reply With Quote
Old 10-28-2009, 02:15 AM   #4
D-Series Ninja
myspace
Eagle H-Beam Rods and Vitara Pistons, 8.5:1 compression and a t3/t4 .50 A/R .63 Hot and little parts here and there. I will need the luck, but that's what Honda Swap is for right? Any positive feedback or info would be helpful. I will probably keep it 75mm and use a block guard?
Old 10-28-2009, 02:33 PM   #5
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
no need for the block guard,but it is extra reassurance...
heres a little tip..let the block sit outside right up until your ready to assemble..take it to the machine shop and have them clean it up and hone it..i know it sounds retarded but thats what our local machine shop guy does and for some wierd reason it strenghtens the cylinder walls and gives a great hone..
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 10-28-2009, 02:42 PM   #6
D-Series Ninja
myspace
Fucking weird Injen...? I am going to hone the cylinders myself but if that works I will go for it! Just trying to figure out how that would strengthen a block. Heating up and cooling off from hot and cold weather or something? I love secret ways to enhance your vehicles performance. If you remove the cloth stripping from the bottom of your hood it adds 1hp and keeps your engine cooler, change to synthetic oil 1hp, Wipe light shampoo and water on your windshield and it will keep it from fogging, Baking soda and a wet rag will repel rain like rain--x. There are so many of these gems we need an epic thread for it. I want to know more of these secrets you guys are hiding from me. lol
Old 10-28-2009, 03:37 PM   #7
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
lol i swear on anything thats how they do it..but anyways..also try to do something about oiling the bottom end..y8 are notorious for spun bearings..i think its something with the oil journals or something
GOOD FAST CHEAP,
Old 10-28-2009, 04:03 PM   #8
D-Series Ninja
myspace
Hmm.. IDK? I will be running oil everywhere when I am finished so that would suck to lose pressure or oil in certain areas. I will have a oil cooler, catch can and lines going through the valve cover and I am tapping into the oil pan too so hopefully it does not end up like this:
I would cry...
Old 10-28-2009, 04:14 PM   #9
D-Series Ninja
myspace
Okay, I looked it up and you are right once again Injen! The Y8 Cranks only have one oil supply hole and the D16a6 has two, which makes it more reliable. So my next question is should I use the a6 Crank in the y8 block? They look almost exactly the same. I don't think it would have any clearance issues.
Old 10-28-2009, 04:34 PM   #10
..is grounded.
dacheat's Avatar
Ride:  '84 buick (rusted)
Rep Power: 268 dacheat has a reputation beyond reputedacheat has a reputation beyond repute
dacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond repute
yay for this thread and pics - i'm subscribing!
marco....
dacheat is offline   Reply With Quote
Old 10-28-2009, 05:07 PM   #11
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
check all the specs for each crank..i dont remember if theres a differance..if its the same then yes you can run the a6..
GOOD FAST CHEAP,
Old 10-28-2009, 09:31 PM   #12
B ( . )( . )B's
Rep Power: 73 Ethan has a reputation beyond repute
Ethan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond repute
Send a message via AIM to Ethan Send a message via MSN to Ethan myspace
I would cry...
Send studs here...
My 91 Civic HB Project
add me on ps3.... my account is "SOHCivic"
Ethan is offline   Reply With Quote
Old 10-29-2009, 12:36 AM   #13
D-Series Ninja
myspace
There is a small difference I noticed, The Y8 crank supports power steering and the a6 does not... Meh, who needs power steering? I just don't want the compression to go any higher than it has to and I need all the clearance.
Old 10-29-2009, 01:57 AM   #14
Greenhorn
Rep Power: 0 chiwhirspi is on a distinguished road
I accept:The Y8 Cranks only have one oil supply hole and the D16a6 has two, which makes it more reliable.
chiwhirspi is offline   Reply With Quote
Old 10-29-2009, 01:57 AM   #15
Greenhorn
_____________________
Devis assurance auto en ligne comparatif voiture | Comparateur simulation devis assurance auto en ligne | Devis assurance auto en ligne
Old 10-29-2009, 02:20 AM   #16
D-Series Ninja
myspace
? welcome to HS.
Old 10-29-2009, 11:00 AM   #17
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
thats why im saying...check the clearnaces and specs...dont just look at it lol..get measurements
GOOD FAST CHEAP,
Old 10-29-2009, 04:15 PM   #18
D-Series Ninja
myspace
Yeah, I am still trying to find a good dial caliper.
Old 10-29-2009, 05:51 PM   #19
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
they are the same you can use any d16 crank
GOOD FAST CHEAP,
Old 10-29-2009, 06:12 PM   #20
D-Series Ninja
myspace
Fuck yeah man, thanks I was hoping for that answer. When I get all the parts gathered up I will swap them out. What would be a better head to use? I have the a6 and the y8. I was thinking the y8 head with a6 intake, TB, dizzy and dsm injectors. I want low compression and high boost?
Old 10-29-2009, 06:55 PM   #21
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
use all the y8 stuff...the intake mani is awesome for boost because of its huge plenum..then id upgrade to a bigger TB
GOOD FAST CHEAP,
Old 10-29-2009, 07:04 PM   #22
D-Series Ninja
myspace
Can you use the y8 Intake Manifold on OBD0?
Old 10-29-2009, 10:39 PM   #23
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
yes but theres some wierd stuff you have to do..its not hard at all
GOOD FAST CHEAP,
Old 10-30-2009, 12:22 AM   #24
D-Series Ninja
myspace
Cool, well I loaned my Camera to friends having a baby, so as soon as they get out I will be able to post more pics up lol. Hopefully good ones, I have been wanting to capture video of my nasty 2-step but there will not be much progress until I get some extra cash flow.
Old 10-31-2009, 07:09 PM   #25
D-Series Ninja
myspace
Well my friends made it out of the Hospital okay, So I will be updating with more Y8 Goodies soon but untill then, here are the images from my last build! My Old D16Z6... We ended up swapping this into my buddies crx and selling it, you can see it in one of the pictures. Enjoy:
I bought my old civic off of a friend after 250k miles and a spun bearing.
Don't judge me, my friends got bored with the spray paint.
The Bay
Honed the Cylinders. I am a clean Freak when it comes to my engines...
Head -
Complete:
I Riced out my Dizzy, but it was cool to watch at night!
Hopefully my next build will go as easy as this one was but I will be keeping it a little bit longer unless I get an offer I can't resist on it. Every man has his price lol.
Oh yah, this is the D16a6 in my DD Crx as of now, Once it's out I will tuck all the hoses, lines and wires...
Tags
complete, crx, d16a6, d16y8, eagle, swap, turbo, vitara
D16Y8 turbo build turbodhatch Engine Building 24 09-20-2009 03:25 PM
D16y8 n/a build philyphreak2127 Civic and del Sol - EG and EK 272 09-20-2009 03:15 PM
are rex's really rare these days? blackdahlia6 Members' Lounge 19 05-04-2009 12:46 PM
d16y8 turbo build...??? CRXSi86 Forced Induction 10 02-13-2009 11:19 AM
Help with my mini me ZC-D16Y8 build welo Engine Building 10 09-09-2008 10:09 AM
