Sensor help on first gen B16A
Old 01-05-2005, 09:17 AM   #1
Rep Power: 17 B16CRX is off the scale
Send a message via AIM to B16CRX
Ok, I was looking in my engine bay earlier (the B16 was put in my car before I got it) and there are a lot of wires that are showing/looking ghetto as hell. So, I started tracing some of them. One in particular that I cant trace just ends and it dangling Another is a single wire going to some sensor just below the Intake manifold. It has a green plug. Two more sensors just below that, right next to the oil pressure sensor (what are these?). And what is the sensor below the distributor? and both plugs below the vtec solenoid are...????
TIA!!
1991 CRX Si
PR3 B16A
62mm BBK TB
Boosted
B16CRX is offline   Reply With Quote
Old 01-11-2005, 06:35 PM   #2
Rep Power: 0 krazie1 is off the scale
Send a message via MSN to krazie1 Send a message via Yahoo to krazie1
I am guessing the one green plug by the dizzy is the vtec pressure switch
and the one behind the manifold is the IAC
krazie1 is offline   Reply With Quote
Old 01-11-2005, 10:57 PM   #3
the ones under the manifold go directly to the block from the harness. not the IACV. Any other ideas?
1991 CRX Si
PR3 B16A
62mm BBK TB
Boosted
Old 01-11-2005, 11:49 PM   #4
The Seniorest Member....
scottp11's Avatar
Ride:  93 Civic CX w/ B16A ,T3/T4 Turbo
Rep Power: 31 scottp11 is just really nicescottp11 is just really nicescottp11 is just really nicescottp11 is just really nice
Send a message via MSN to scottp11 myspace
Maybe your TPS? Can you post pix?
93civicCXB16A...T3/T4 turbo
00civicSI...CRVtec
93integraLS...GSR
My build thread! : http://nwp4life.zeroforum.com/zeroth...d=27937&page=1
scottp11 is offline   Reply With Quote
Old 01-18-2005, 01:39 PM   #5
Rep Power: 13 Spunkster is off the scale
The one on the back of the engine under the manifold is most likely the knock sensor wire. It really all depends on who didd the wiring harness and where the harness came from.
Spunkster is offline   Reply With Quote
Old 01-19-2005, 12:56 AM   #6
Rep Power: 11 HONDA_F1 is off the scale
Send a message via AIM to HONDA_F1
the greeen plug under ur intakemanifold is probaly the knock sensor
the 2 near the distributor are vtec oil and solenoid
and there might be one more getto looking wire going to ur exahust manifold that would be the 2nd o2 sensor
g2 integra w/ b16
<a href=\'http://f3.mine.nu\' target=\'_blank\'>http://f3.mine.nu</a>
HONDA_F1 is offline   Reply With Quote
