si intake manifold
Old 07-28-2004, 01:51 PM   #1
Rep Power: 0 NoBoost is off the scale
Thumbs down
will my mpfi si intake manifold fit on my dohc zc?
NoBoost is offline   Reply With Quote
Old 07-29-2004, 12:51 AM   #2
Ride:  1989 Honda CRX HF
Rep Power: 28 MugenCRX is an unknown quantity at this point
Send a message via AIM to MugenCRX
They are both D-Series, correct? If so, I would imagine that it would. I suggest taking off the ZC one and either try bolting on the SI one(what will you lose except time?) or comparing the bolt patterns and plenum ports. If they match, you should be good to go.
They say that you only live life once, but if you live like me....once is enough!
-Frank Sinatra
MugenCRX is offline   Reply With Quote
Old 07-29-2004, 02:23 PM   #3
Rep Power: 12 racingtopher is off the scale
it might bolt up, but it might not line up correctly.
Because the d-series headers bolt up okay, but they are a little off, and the exhaust hits the edges of the header flange.
racingtopher is offline   Reply With Quote
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
