I have a b16a swapped into my 90 CRX Si and want a new intake manifold. Skunk 2 has one for the b16a, but of course it's not specific to the b16a1. Only has them for the DelSol and 99-00 Civic Si B16a, but same part number, so same part. Will this fit in the b16a1 on mine??
Wiring Guru
Yes it will fit. I can't remember, but you may have to plug a vacuum line or tee an extra one off.
www.JKOBD.com The Original OBD Harness Guru ~ Auto ECU Conversion Harnesses ~ Worldwide traveling Tuner 10.10@152 with da clutch slipping 00 Turbo Civic Street car - ITR Tranny FTW |
#5 |
Good book! How'd ya like that Stock Extrude Honed intake dyno? Can't see paying $485 to get those gains though.
Decent dyno site: http://www.importreview.com/dyno.html |
#6 | |
#7 |
Wouldn't doubt it B...both are pretty close with nearly stock internals. Dyno in the book is of a b16 with i/h/e, Crower401's but I only saw a .6 difference in peak hp and 3ft-lbs difference in peak torque. With that setup and stock intake the powerband looked better up to 8k, then the skunk started taking over.
#9 |
Ride: 89 honda crx si
yeah the skunk2 will work for the b16a1... the b16a1 came from the delsol weirdly when i was looking for a valve cover gasket it toke me and the guy at checker about and hour looking tho all the books looking for the b16a1 cuz i thought that it came from and early integra...so about after and hour of that we found that its from the delsol so im pretty sure it will work.
#10 |
Führer Mod
fail
