This is a discussion on Starter question, Z6 into EF hatch in the HYBRID -> ED-EF / DA forum
i'm pretty sure it would work fine. if all else fails, just put the a6 flywheel on....
| | #1 |
| i'm pretty sure it would work fine. if all else fails, just put the a6 flywheel on. |
| | #2 |
| dont you have to use the starter that goes to teh tranny? so you would need to use the Si starter....how did you get a Z6 clutch/flywheel to work with an 88-91 Si tranny? the spline count *should* be different... |
| | #3 |
| im using a 92-95 starter on my 88 si tranny...works better than stock!!! |
