swapped a b18a1 into my 91 civic engine turns but wont start
Old 11-20-2009, 04:50 PM   #1
Ride:  91 civic hb soon to be b18
steel205 can only hope to improve
Default swapped a b18a1 into my 91 civic engine turns but wont start
i just recently swapped a b18a1 from a 90 integ into my 91 civic i plugged all the wires from the civic harness into the integra engine the engine turns over but does start and there is a wierd buzzing sound in my dash when u turn the key to on any help would be appreciated i am starting this new thread because it is a new problem so if anyone can help me out that would be amazing
steel205 is offline   Reply With Quote
Old 11-22-2009, 10:50 AM   #2
91_stylin_civic's Avatar
Ride:  2008 honda civic SI,91 civic hatch w/b16 and 91 civic hatch project car
91_stylin_civic has a spectacular aura about91_stylin_civic has a spectacular aura about
check the grounds
91_stylin_civic is offline   Reply With Quote
Old 11-22-2009, 02:20 PM   #3
Ride:  95 eg b18c
shdw b18c is on a distinguished road
it sometimes take a while to start so that the fuel pressure builds up and check all your grounds. it took me a few times before it started i just keep cranking it and them vroom but check all that and then crank it up again you might want to check fuel pressure.
shdw b18c is offline   Reply With Quote
Old 11-26-2009, 02:25 AM   #4
90alltrac is an unknown quantity at this point
which ECU are you using??
90alltrac is offline   Reply With Quote
Old 12-03-2009, 02:36 AM   #5
Ride:  civic/tegra
kidkg24 is on a distinguished road
Send a message via AIM to kidkg24
Are you using a injector resistor box? Is their spark? Is it getting gas... with the stock wiring you need the resistor box or their will be no injectors firing. If you have no spark ckeck the wiring to the dist. if its good try a new coil.
kidkg24 is offline   Reply With Quote
Old 12-05-2009, 12:51 PM   #6
Ride:  91 civic hatch
turboef87 is on a distinguished road
could b ur getttin no spark check ur coil
turboef87 is offline   Reply With Quote
Old 12-08-2009, 10:20 AM   #7
ZCpowerdSI's Avatar
Ride:  91 Si Hatch, DOHC ZC
ZCpowerdSI will become famous soon enoughZCpowerdSI will become famous soon enough
sounds to me like a ground... had the same problem. made a weird buzzing sound.. turns out the ground on the bracket for the clutch cable which is on the tranny was a little rusted.
ZCpowerdSI is offline   Reply With Quote
Old 12-09-2009, 12:46 PM   #8
Ride:  90 crx w/zc dohc
Fernpatch has a spectacular aura aboutFernpatch has a spectacular aura aboutFernpatch has a spectacular aura about
myspace
Check the ground at the thermostat housing
Fernpatch is offline   Reply With Quote
Old 12-09-2009, 02:12 PM   #9
thnx all and ya it was the ground on the tstat that was loose fried my relay but got a new one started right up and well its pretty damn fast now
Old 12-12-2009, 01:05 PM   #10
ZCpowerdSI's Avatar
Awesome to hear that!!
Old 12-17-2009, 01:59 PM   #11
ya she boogys nicely spins first an second no problem and i dont even have to powershift like i had to with the sohc zc
Old 12-22-2009, 09:06 AM   #12
34diesel34's Avatar
Ride:  91CRX SI & 97 ACCORD
34diesel34 is just really nice34diesel34 is just really nice34diesel34 is just really nice34diesel34 is just really nice
What wires are these. There's two of them. One is black/yellow, the other is light blue. These wires were on the B16 I just put in but they are cut. I have the same two wires on my 91 crx si but they have a plug like they plug in somewhere. I dont recall using them before with the sohc engine.
34diesel34 is offline   Reply With Quote
Old 12-22-2009, 10:15 AM   #13
myspace
G151: 2 black, 1 brown/black, a red/black, center of engine compartment. The wires should come together in a set of ring terminals.
Old 12-22-2009, 12:35 PM   #14
well to figure out wat they are u are going to have to find a sensor or or a plug on the engine that doesnt have anything plugged in
Old 12-22-2009, 01:10 PM   #15
34diesel34's Avatar
Everything is plugged in. It's a jdm B16a. Those wires were grounded together on the thermostat housing, and cut off when the engine was pulled in japan. My 91 crx si harness doesn't have those wires.
Old 12-22-2009, 01:25 PM   #16
well does it start and does it thro any codes
Old 12-22-2009, 02:55 PM   #17
myspace
Unless they were cut off there should be a small bundle of ground wires on the stock si harness that goes to the thermostat housing. I remember that from the first time i replaced the motor in my old 91 si hatch. The motor had the ground wires clipped of so when I was checking my wiring after the install a saw wires attatched to the housing but didn't realize that they were clipped off and the ones from my harness were hanging out in space. The funny thing is it would start but in ran shitty and I had relays buzzing and lights flickiring in the dash. Took me a little while to figure out what was up with that.
What I write is my own opinion based on what I have done. Your own results may vary...
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you." --Anonymous
Old 12-22-2009, 03:00 PM   #18
lol when i did my b18 swap recently (first one) i didnt have the thermostat ground hooked up the car wud turn but not start and the relay made the worst buzzing noise ever then when i hookedd up the ground i found out i had fried my relay ($81 later ) it runs mint
Old 01-20-2010, 08:22 PM   #19
Greenhorn
linuswow is on a distinguished road
fernpatch thank you so much i f-ed up and dident fully tighten that dang bolt up thanks again
linuswow is offline   Reply With Quote
h22 turns but wont start, HEEELLLPPPP!!! kingcross1000 Accord 1 10-23-2009 11:48 AM
zc swapped 89 si hatch wont start/starter breaks when trying to crank jdmontheway HYBRID -> ED-EF / DA 1 07-06-2008 12:10 PM
B18a1 swap wont start EFhatch4 HYBRID -> ED-EF / DA 4 09-21-2007 11:20 PM
B18a1 in a CRX, WONT START........ CReX123 HYBRID -> ED-EF / DA 12 06-18-2004 02:24 AM
turns over but wont start. Mattndew676 General Tech and Maintenance 5 09-13-2003 02:34 AM
