tps wiring
Old 05-23-2006, 05:36 PM   #1
Rep Power: 8 regal1975 is off the scale
I am oh so close to having my rex running...
i have a pm6 ecu.. d15b vtec motor
tps was dead... and i noticed that the stock tps wouldnt work at all.. forget wiring it backwards, it would have locked the throttle in place....
soo.. new tps.... but how do i wire it up??
what stock wire color from the stock 89 crx dx wiring harness will go to exactly what pin on the tps? it is a normal tps similar to what came on the crx si...
Thanks a ton
regal1975 is offline   Reply With Quote
Old 05-23-2006, 11:52 PM   #2
after a few hours of work..... i figured out why the wires need to be swapped... working now.. other problems but ill start a new thread.. thanks much to the FAQ on this site.... this is by far the best swap site on the net... 15+ forums ive tried....
