I put a zc in my car recently and had problems today. I was pulling out of dairy barn, I get to 3000 rpms, go to shift to second, there was a loud pop and I couldn't put it into gear...Pulled over, put it in gear, let off the clutch and the engine died. So I ask you, is this a tranny problem? if so what axles do I need for the zc tranny...and don't tell me 86-89. A guy tried that and it twisted and messed those axles up bad.
So, I need to know which axles work on the zc tranny, and if I need to change anything else to make the axles I need work. URGENT! ANSWER ASAP PLEASE! |
i beleive you use crx si axles if this is into an EF,
http://www.midwesthybrid.com |
ZC transmission uses a ZC intermediate shaft and 90-93 Integra axles - you will need to remove the rubber seal ring from the outer CV joint where it meets the hub - pop right off with screwdriver
ZCspeed Racing |
| my tranny problems help!! | timbit | General Tech and Maintenance | 0 | 11-15-2003 12:34 AM |
| Tranny Problems? | Raxx | General Tech and Maintenance | 2 | 05-14-2003 07:23 AM |
| Tranny Problems | seerx | HYBRID -> EG-EK / DC | 0 | 04-22-2003 10:16 AM |
| Problems W/ Auto Tranny | pLop | HYBRID -> EG-EK / DC | 6 | 03-25-2003 11:04 PM |
| Zc Tranny Problems. | hardweapon | HYBRID -> EG-EK / DC | 1 | 03-24-2003 11:07 AM |
