trans swap manual to hydro clutch?
Old 01-23-2005, 08:52 PM   #1
Rep Power: 11 88rex is off the scale
Post
hi i have an 88 crx hf i want to swap in a better trans si trans are hard to find now but i have a 93 del sol scoupe trans. i no i have to change the hubs to dx or si for the axles to fit but where can i get a manual clutch to hydro conversion .this is also a d series trans to.
88rex is offline   Reply With Quote
Old 01-24-2005, 06:49 PM   #2
ryan89crx's Avatar
Ride:  '89 CRX HF, a6 motor/trans, HMT turbo kit
Rep Power: 15 ryan89crx will become famous soon enough
Send a message via AIM to ryan89crx Send a message via MSN to ryan89crx
nobody makes the hydro conversion for d series trannys. your best bet is a 89-91 si tranny. 88 will work, but the splines are different and the clutches made for them are a little smaller because they came with a smaller flywheel, but since your car is an 88, it will be best for you so you dont have to change your flywheel to adapt to a bigger clutch that work in the 89 and 90-91 trannys
www.d-series.org for all you D motor guys
ryan89crx is offline   Reply With Quote
Old 01-24-2005, 06:57 PM   #3
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 122 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
You can convert to hydro, not worth it if its a d series though, use all the stock lines and everything from a 92-95 civic. The mounts should work, if the tranny mount doesn't you can probably use the hf mount for it.
I would also reccomend the 88-91 si trans though.
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 01-24-2005, 09:01 PM   #4
angry bear
ripperbone's Avatar
Ride:  02 Acura RSX
Rep Power: 44 ripperbone has a spectacular aura aboutripperbone has a spectacular aura aboutripperbone has a spectacular aura about
Send a message via AIM to ripperbone Send a message via Yahoo to ripperbone
if your looking for a si d series tranny I have one on my 90 crx si I going to get rid off, let me know if your interested
XBL: ripperbone
Vouches / Good buyers or sellers = * pissedoffsol* socolsvtec* lshatchcx18* hybrid89* aafryf* integraracing91* twistedimage* NoJokE* 5speed4life* Estorvito* sheekdude* antonio* VTECPOWER* 98hybrid* traitorzxiong* preludebuddy* wanderinman* TurboMirage* kaoskustoms* B16RacerN2NR* HPHP80620*
ripperbone is offline   Reply With Quote
Old 01-25-2005, 09:54 AM   #5
price on the tranny shipped to pleasant gap pa 16823 thanks looking to buy asap
Old 01-26-2005, 10:41 PM   #6
angry bear
ripperbone's Avatar
Ride:  02 Acura RSX
Originally posted by 88rex+Jan 25 2005, 08:54 AM--><div class='quotetop'>QUOTE(88rex @ Jan 25 2005, 08:54 AM)</div><div class='quotemain'><!--QuoteBegin-ripperbone@Jan 24 2005, 09:01 PM
[/b][/quote]
I find out this week have to make some calls to different freight companys.
XBL: ripperbone
