v-tec kickin when?
Old 08-26-2003, 04:53 PM   #1
Rep Power: 13 K-V-NO is off the scale
Thumbs up
just installed ctr cams in b16, v-tec now kickin @ 4800rpm, should i have the ecu chip and have v-tec kickin later. any suggestions?
K-V-NO is offline   Reply With Quote
Old 08-26-2003, 05:07 PM   #2
sohcslammer's Avatar
Rep Power: 35 sohcslammer is an unknown quantity at this point
No.
Latest project -
1 fucking fast 99 SI
sohcslammer is offline   Reply With Quote
Old 08-26-2003, 05:52 PM   #3
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
Changing your cams won't change your crossover point.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 08-26-2003, 06:15 PM   #4
I started to type that too and realized he just worded it fucked up. He is asking if he should chip his ECU to cross it over l8r. I'm not sure what a B16's stock X-over is so I figured it was @ 4800. That seems a little low now though.
Latest project -
Old 08-28-2003, 09:58 AM   #5
Rep Power: 23 cycloneb18c3 is off the scale
Send a message via AIM to cycloneb18c3
what ecu are you using? 4800 sounds like a SOHC, a spoon chipped ecu, or that ur using a vtec controller. I dont think any stock honda program kicks the vtec at 4800 for a dohc.
whoever said nothing is impossible, never tried slamming a revolving door
cycloneb18c3 is offline   Reply With Quote
Old 08-28-2003, 10:18 AM   #6
GSRCRXsi's Avatar
Rep Power: 88 GSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of light
i dont know ecu specs or anything but i wouldnt doubt that vtec could kick in at 4800 stock. hell my b18c hits vtec at 4400. and yes thats the stock crossover point with the stock obd1 p72 ecu.
91 CRX si
95 Integra LS
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
Old 08-28-2003, 10:34 AM   #7
the stock b16 ecu is being used, seems like its kickin a little too early, no, should it be set to kickin later. someone mention to chip ecu and have v-tec set @ 8000rpm and get a v-tec controller to set my v-tec.
Old 08-28-2003, 11:08 AM   #8
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Setting your vtec at 8000 is also usless, unless you have cams and a valve train that can rev higher than that and make power. The P30 is 5500 I believe, or 5800, but you probably have a PR3? I think the cross over on those is a little lower.
95 CX|B16A2
Old 08-28-2003, 11:47 AM   #9
Rep Power: 15 CRXRookie is off the scale
Wow, whoever told you to set the vtec at 8000 rpm is a complete moron.
CRXRookie is offline   Reply With Quote
Old 08-28-2003, 11:54 AM   #10
Rep Power: 14 90crxb16a is off the scale
i have a pr3 on my b16 and my Vtec kicks in at 5500 rpm's
Is it ever fast enough?<a href=\'http://www.240sx.org/links/hos/pos-crx.jpg\' target=\'_blank\'>click on this pic</a>
Tonyd0821 ripped me a new asshole, and all i got was this lousy fucking sig.
90crxb16a is offline   Reply With Quote
Old 08-28-2003, 12:58 PM   #11
Arrow
mine's a pr3, v-tec was kickin @ 5500, since installin the ctr cams it's @ 4800
Old 08-28-2003, 01:09 PM   #12
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
There you go.
95 CX|B16A2
Old 08-28-2003, 01:45 PM   #13
Rep Power: 18 khai_tuan_nguyen is off the scale
What is a Pr3-3 on a head? 99-00 civic si?
<a href=\'http://www.hondaswap.com/forums/index.php?act=module&module=gallery &cmd=user&user=25607&op=view_album& album=107\' target=\'_blank\'>PICTURES: Type R Stuff/ B-Series Parts for Sale</a>
khai_tuan_nguyen is offline   Reply With Quote
Old 08-28-2003, 02:06 PM   #14
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
B16A casting code, it is also on the block underneath on the driverside
95 CX|B16A2
Old 08-28-2003, 04:02 PM   #15
Rep Power: 28 Bl6CRX is off the scale
Send a message via AIM to Bl6CRX Send a message via Yahoo to Bl6CRX
Yeah, im not sure if id have it that low, more like 5200-5500 sounds better but besides that it would be fun to have VTEC kick in at 8 (i know its a stupid idead for performance) but when we were bored one day and started messing with my bros VAFC and made it kick in at 6500ish the cross over is intense, pulls so hard
Bl6CRX is offline   Reply With Quote
Old 08-28-2003, 04:30 PM   #16
seanjuan's Avatar
Ride:  See sig.
Rep Power: 23 seanjuan is off the scale
Vtec crossover shouldn't be "intense", if tuned properly it should be a continuos power gain with no drastic spikes
it is my understanding that you should not "feel" vtec, it should be a smooth transition into the high lobe. at least that is what my car is like I have a stock jdm P30 and vtec engages anywhere from 5800 to 6500 depending on how hard I'm accelerating. the only thing I notice when vtec kicks in is a change in the sound of the engine as it starts to breath more
the stock ECU takes more factors into account than just rpm to determine when to switch to the high lobe on the cam, and unless you have tuned the vtec point on something other than a butt dyno you probably shouldn't mess with Honda's engineering
flame on
edit: it's very possible that installing new cams could change the vtec point because the ECU should be able to adapt to the new cams
'92 Civic LX - for auto-x
'03 Suzuki SV650 - for speed
'02 VW GTI 337 - for fun
seanjuan is offline   Reply With Quote
Old 08-28-2003, 05:51 PM   #17
You are right in the fact that VTEC should be a smooth transition and not be "intense" but your X-over does NOT switch with throttle and cams. A ECU is programed to switch cam lobes at a pre-determened RPM. Always.
Latest project -
Old 08-28-2003, 06:14 PM   #18
Rep Power: 16 omega11855 is off the scale
n3g(negative) cams wont automatically change vtec point ecu cant adapt like that
but depending on load if ecu is still in closed loop vtec wont kick in neccisarily at a specified rpm for example i just drove to san fran and when i was coasting (dont ask but from la to san fran it was like 4.5hrs)(great time) at 5900 vtec didnt kick in it only kicked in if i got it to 6200 coasting ie not floored this is on a stock p73 ecu vtec point changes based on conditions but there are set parameters as i said regardless of how much throttle at 6200ish it changed over no mater what
&quot;Girls are like cars u can have as many as you can afford but you can only drive one at a time&quot;~Me
<a href=\'http://www.jzperformance.com\' target=\'_blank\'>Jz own meee</a>
omega11855 is offline   Reply With Quote
Old 08-28-2003, 06:22 PM   #19
seanjuan's Avatar
Ride:  See sig.
this is what I found about vtec crossover
When to Switch Camshafts
The ECU is constantly comparing the torque curves of the low and high speed camshafts. It calculates the expected volumetric efficiency of the engine based on the current environmental conditions (air temperature and pressure) and the engine conditions (temperature, engine load, throttle position), and then derives the expected torque from the volumetric efficiency for each camshaft. Most of this has to be done anyhow in order to determine how much fuel to inject.
When conditions are right (the revs are over about 4500 rpm, the engine is warm, there is enough oil pressure to activate the pistons and the car is moving) the ECU will switch from the low to high speed camshaft when the expected torque of the low speed camshaft equals the torque of the high speed camshaft.
this is the page it came from
it seems to make sense to me
Old 08-28-2003, 06:22 PM   #20
Edit: OK, you're right.
And I made it from Lafayette to LA in 4 hours 10 minutes so (Yes, it's about 110-120 the whole way with 1 stop.)
Latest project -
Old 08-29-2003, 02:08 AM   #21
Rep Power: 16 ChrisSiR is off the scale
5800? ive got the b16a with what i think is the pw0 ecu.... as soon as the oil is warmed up enough, i hit vtec at 4K.... and its not a smooth transfer, in first and second gear..... is this not normal?
<span style=\'color:blue\'>1988 Crx Dx (<a href=\'http://turbogizzmo.com/gallery/view_album.php?set_albumName=Crxpic s\' target=\'_blank\'><span style=\'color:red\'>Dubbed the Go-Kart</span></a>) <span style=\'color:red\'>?hp 178tq</span></span>
<a href=\'http://Coracin.net\' target=\'_blank\'>CoRacing.net</a>
<span style=\'font-size:13pt;line-height:100%\'><span style=\'color:blue\'>I swear, all girls should come with their own carfax report...</span></span>
ChrisSiR is offline   Reply With Quote
