Facebook Twitter
vtec test???
This is a discussion on vtec test??? in the HYBRID -> ED-EF / DA forum
im not sure if my vtec is working properly, i believe i wired everything up correctly but at the same time i cant feel/hear the vtec kick in when accelerating. Is there a way i could test to see if the vtec is indeed engaging? ...
Old 04-30-2004, 05:51 PM   #1
Arrow
Someone on here said that the CRX HF has a Shift light on the dash that you could tap into the vtec wire so that it would light up in vtec, so could i just wire in a bulb of some sort to test?
any help would be appreciated.
thanks
the_rail is offline   Reply With Quote
Old 04-30-2004, 07:26 PM   #2
Citizen_Insane's Avatar
I would like to know anything about the VTEC light HF mod. Sorry, don't mean to thread jack
Citizen_Insane is offline   Reply With Quote
Old 05-01-2004, 10:57 PM   #3
you should be able to tell with a b16.... if u arnt feeling/hearing it it isnt working.
cycloneb18c3 is offline   Reply With Quote
Old 05-02-2004, 12:01 AM   #4
[b]you should be able to tell with a b16.... if u arnt feeling/hearing it it isnt working.
civic_types is offline   Reply With Quote
Old 05-02-2004, 12:37 AM   #5
no i dont think that thread was a vtec test,they probobaly used there tach and shift light to make vtec engage,a result of ghetto rigging it that way is that your shift light comes on when it kicks in because they are using the same signal,one to signal to let you to know whan to shit then u use that same signal to tell your ecu when to engage vtec. i dont know if that makes sence or not.
PHOBIA is offline   Reply With Quote
Old 05-02-2004, 06:41 PM   #6
haha if you can hear it and feel it its working, theres no mystery vtec...
Bl6CRX is offline   Reply With Quote
Old 05-02-2004, 06:46 PM   #7
Whats the stock RPM engaugement point for VTEC on a b16 sir1?
Old 05-02-2004, 06:46 PM   #8
Old 05-02-2004, 10:22 PM   #9
you ll know when VTec is engaged..........it will rev to 8K very fast. it doesnt go into Vtec and push you back in your seat, its not like a Big Block Chevy or a turbo car. when youre haulin ass and the RPM's increase quickly thats when Vtec kicks in.
RSBAD454 is offline   Reply With Quote
Old 05-02-2004, 11:30 PM   #10
on my first gen b16 vtec engages at 5.5k if you get a controller you can change it to your liking or chip your ecu.
Old 05-02-2004, 11:32 PM   #11
in my car its real distinct.especially with the greddy B) it sounds like a loud ass motercycle at full throttle.
Old 05-03-2004, 01:43 AM   #12
i believe that b16a is 5200 using a pr3
b16a obd 0 tune up parts list feet_ HYBRID -> ED-EF / DA 6 12-27-2007 07:50 PM
How to wire vtec xj0hnx General Tech Articles 3 06-17-2005 05:13 PM
Engine Swaps 101 pissedoffsol Swap Articles 0 01-11-2004 06:54 PM
Part Numbers for 89Si/B16 OBD0 Swap steelbuster Swap Articles 0 11-16-2003 06:36 PM
LS-VTEC/CR- VTEC Info pissedoffsol General Tech Articles 1 11-10-2002 03:19 AM
© 2001-2013 HondaSwap.com
