what do i need to swap a 92 integra engine in a 90
Old 01-15-2005, 05:04 PM   #1
Rep Power: 0 240mph is off the scale
ok first i wanna say whats up to everyone here.
my problem is this i have two integras one is a 92 obd1 and the other is 90 obd0.my main question is this; what do i need to do to complete my swap .putting the 92 engine in the 90 body.what wires do i need to change or extend.or anything.thanks
240mph is offline   Reply With Quote
Old 01-16-2005, 01:52 AM   #2
You need:
Alternator, Distributor, ECU & Injectors from the 90 LS.
good luck
90 Integra Sedan
B20V 225 / 153
Old 01-17-2005, 12:16 AM   #3
Wiring Guru
Rep Power: 11 JKOBD.com is off the scale
It depends on what electronics you want to go with. If you want to use the OBD0 electronics, you will need to keep the OBD0 distributor, 1 wire O2 sensor and ecu.
If you want to go to OBD1, you will need an OBD0-1 conversion harness and use the OBD1 distributor, 4 wire O2 sensor and OBD1 ecu.
The injectors are optional between OBD0 and OBD1. Let me know if you need a harness or some more information for this swap.
Jason
OBD Conversion Harnesses
www.JKobdconversionharness.com
www.JKOBD.com
The Original OBD Harness Guru
~ Auto ECU Conversion Harnesses ~ Worldwide traveling Tuner
10.10@152 with da clutch slipping
00 Turbo Civic Street car - ITR Tranny FTW
JKOBD.com is offline   Reply With Quote
Old 01-17-2005, 12:25 AM   #4
FüK-VTEC
civicious's Avatar
Ride:  07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Rep Power: 189 civicious has a reputation beyond reputecivicious has a reputation beyond repute
civicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond repute
Send a message via AIM to civicious myspace
What do you mean by 'the injectors are optional between obd0 and obd1'?
CMRA #265
http://www.myspace.com/civicious
AIM: greyfades
civicious is offline   Reply With Quote
Old 01-17-2005, 12:36 AM   #5
Wiring Guru
The injectors and ecu are not dependant on what OBD you run. If you run the OBD0 injectors, you must keep the resistor box in the curcuit. If you run the OBD1 injectors, then you must solder the 5 wires together at the resistor box and remove it. You can run OBD1/2 injectors with an OBD0 ecu and vice versa.
Jason
www.JKOBD.com
Old 01-17-2005, 01:37 PM   #6
Im almost positive that he just wants his car to run. so therefore he can run teh OBD1 engine OBD0.
90 Integra Sedan
B20V 225 / 153
Old 01-23-2005, 03:51 PM   #7
Rep Power: 17 CRseX84 is off the scale
Send a message via AIM to CRseX84 Send a message via MSN to CRseX84 Send a message via Yahoo to CRseX84
yea just swap it to OBD0 much easer.... Just get the injectors, Dist. alt. and ECU.. much much less headache
CRseX84 is offline   Reply With Quote
