| | LinkBack | Thread Tools |
| | #28 |
| Senior Member Join Date: Feb 2008 Location: woodstock Age: 25
iTrader: 0 / 0% Ride: 89 CRX SI (LS)
Rep Power: 6 | It's the obd-0 ls rail. I don't see why you couldn't change the cap and fpr around as long as it seals it would be no different the whole rail is pressurized the only way out is the fpr I don't think it would matter moving it that far. Then again I'm not Japanese. |
| | #30 |
Rep Power: 6 | I can't see how it would hurt anything you would only be moving it a couple inches, it would still be on the far end of the rail. If everything bolts up it wouldn't hurt to try, you might spill a little gas at most, it couldn't hurt the motor any it will still get fuel no problem. You have to pull that endcap off and see what it looks like, I have never had it off, as long as the surface will compress the o-ring and seal and still let gas through the center it should work. |
| Holley SC fuel rail - Sport Compact Fuel Rail | RSS-Bot | Auctions | 0 | 05-16-2009 06:50 PM |
| Aem fuel rail with aem fuel pressure regulator b-series | RSS-Bot | Auctions | 0 | 02-09-2009 01:36 PM |
| Fuel injector clinic fuel rail fic eclipse talon turbo | RSS-Bot | Auctions | 0 | 01-15-2009 06:03 PM |
| AEM fuel rail and adjustable fuel pressure regulator | RSS-Bot | Auctions | 0 | 04-24-2008 06:03 PM |
| Str Fuel Rail Install Pics | D See 2 | Members' Lounge | 13 | 03-03-2003 11:42 PM |
