What should i do
Old 07-29-2004, 02:54 PM   #1
Rep Power: 12 joesbadcrx is off the scale
I need to know if i should sell my d16a1 dohc.And how much should i sell it for.Also what other motor should i get to fit in my 90 crx hf. And what would be a easy swap to do for it.
joesbadcrx is offline   Reply With Quote
Old 07-29-2004, 03:39 PM   #2
Rep Power: 13 The WORLD is yours... is off the scale
look at your other post about your swap!!
but, if it is the brown top then yes sell it. you can not drop it into your 88 crx hf!! for direct engine swap's then most any D-series engine will be better then what you have!! i.e. D16a6, D16z6, D15b(vtec), D16y8, ect..
now if you want to go with the big boy's the B-series!! they're not a "direct" swap. you'll need mounts, shift linkage, axles, etc.. etc... there plenty of swap guides on this site and on the net. for the B-series swap into a 88-91 crx/civic!! just search it.
~InstiGatoR~ 89 CRX si B18c JDM GSR, 90 ls tranny, exedy racing clutch kit, ACT pro lite 8.8lbs aluminum flywheel, victor X IM, short ram intake, 90 ls header, greddy SP2 cat-back exhaust, skunk2 adj. cam gears, B&M F.P.R and F.P.G, Hasport Billet mounts, OBD1 convert'd, chipp'd P72 ecu using Uberdata, H&R racing springs, tokico Blue's, DC sport short shifter, DC sport front and rear strut bars. install'd my zex dry kit!!
soon i'll be putting on my WW rs body kit. customizing a FG hood for my engine. going turbo(maybe/maybe not). datalogging with Uberdata. the list goes on!
The WORLD is yours... is offline   Reply With Quote
Old 07-29-2004, 03:42 PM   #3
Ride:  1989 Honda CRX HF
Rep Power: 28 MugenCRX is an unknown quantity at this point
Send a message via AIM to MugenCRX
You only need to post shit once.
They say that you only live life once, but if you live like me....once is enough!
-Frank Sinatra
MugenCRX is offline   Reply With Quote
