This is a discussion on Will Y1 LSD fir on LS trans in the HYBRID -> ED-EF / DA forum
I just want to know if my LSD off a Y1 cable tranny fit on my 93 LS transmission with no modifications, The LS i think is 90% sure its A YS1 ....
| | #1 |
| I just want to know if my LSD off a Y1 cable tranny fit on my 93 LS transmission with no modifications, The LS i think is 90% sure its A YS1 . |
| | #2 |
| ANybody |
| | #3 |
| All b series parts are interchangeable (sp?) it will fit in the LS the LS is a YS1, but a USDM YS1 |
| | #4 |
| LEAN thanks & thanks again since your the only one to respond to my ?. JUST to clarify the LSD off A JDM Y1 factory LSD tranny,will fit a USDM 93 integra LS (YS1)tranny. |
| | #5 |
| if you are asking if the LSD from the Y1 will work in the YS1, then I'm not sure, I do know you can replace a YS1 with a Y1 with not problems. |
| | #6 | |
| Quote:
| | #7 |
| b-series hydro are NOT. b16/ls share the same ring gear size, while gsr/itr/ctr share a different ring gear. i do not know about cable, however... but keep this info in mind. |
| | #8 |
| From what I've seen, the cable and hydro internals are the same with their respective label... the clutch actuation is the only thing different. |
Similar Threads | ||||
| b18a1 into 91 dx trans ? | javenger | HYBRID -> ED-EF / DA | 7 | 04-27-2004 11:38 AM |
| Leak from a new trans?? | 4DRonDUBS | General Tech and Maintenance | 5 | 03-25-2004 01:13 PM |
| zc trans in dx case | cavrx | HYBRID -> ED-EF / DA | 8 | 12-16-2003 07:38 AM |
| WS6:Firehawk | SolPWR | Members' Lounge | 30 | 09-05-2003 06:39 AM |
| Sir Trans On B16a Turbo | possessed imports | Forced Induction | 9 | 05-04-2003 12:06 AM |
