wiring for mini me swap
Old 11-16-2006, 12:06 AM   #1
dj30224's Avatar
Ride:  1989 Honda Civic Std.
Rep Power: 7 dj30224 is on a distinguished road
Send a message via AIM to dj30224
Default wiring for mini me swap
i have a 1989 honda civic std canadian model im gonna do a mini me swap i have everything to do the swap exept wiring i need to know what wiring i should use someone told me that 92-95 ex wiring would work but said i would have to run two additional wires to the engine any help would be useful
thanks,jason
dj30224 is offline   Reply With Quote
Old 11-16-2006, 11:40 AM   #2
jlicrx's Avatar
you need to use the engine harness that is on your car and make the wiring changes to it to convert from DPFI to MPFI, and also add any other wires required for VTEC, etc. - engine wiring harnesses are not interchangeable
ZCspeed Racing
jlicrx is online now   Reply With Quote
Old 11-18-2006, 10:32 AM   #3
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
-P28 ecu ('92-'95 Civic EX/Si)
-B/S/T forums here and on Honda-Tech.com
-Boomslang Fabrication's obd0 to obd1 harness
-Click me
-obd0 to obd1 Distributor adapter
-B/S/T forums or make your own. (my sig)
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
LS Swap Into 91CRX HF WIRING!!!!!!!!!!!!!!!!!!!!!! ExclusiveImports Civic and CRX - EF 9 09-27-2008 09:55 AM
99-00 civic Si cluster swap into EF How To (pics0) B18C5James HYBRID -> ED-EF / DA 30 07-11-2007 06:25 PM
vtec wiring for a jdm d15b swap? 92civy HYBRID -> EG-EK / DC 1 09-07-2006 07:22 PM
Free set of VX wheels wiring my swap. GSR into VX dwnthehatch HYBRID -> EG-EK / DC 3 08-24-2003 05:15 PM
H22a Wiring Harness For My Swap 300hph22civic Engine Building 4 02-09-2003 04:13 PM
