i have a 93 ls in a 1990 hatch . i have already done the dualpoint to multipoint( i did it the right way to i got a custom harness from hasport cost me a lot of money to like $315 with the cost of the a uncut dx harness and an uncut obd-0 ls(91) harness)
my motor runs but only on 1 cylinder( cylinder 4 or the leftmost cylinder when lookin at motor from front of car) i have great compression on all cylinders, i have fire on all cylinders, and i have fuel on all cylinders/ my injectors are pulsing and my injector plugs are pulsing i have everything that it takes to make a motor run why isnt it runing on all four clyinders i have tried switching my plug wires around everyway possible but no luck what could it be??? please respond thanks daniel a.k.a. blngblngskater |
FüK-VTEC
Ride: 07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Bad plug wires.
edit: Even if you have fire, you may not have enough fire. This was one of the problems I had when I first put the B16 in my hatch. Replace the plug wires. |
The Trisexual
Ride: 2007 Civic, 1995 Jeep Grand Cherokee
replace the wires like civicious said and the cap and rotor.
DO NOT PM ME WITH TECH QUESTIONS!!! Current Rides 1992 Chevy S-10 Ext. Cab Previous 1992 Civic DX Hatch = 1994 B18B1 Turbo Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned, 253whp 1994 Civic VX Hatch, 1992 b18a1 swap 1993 Civic CX Hatch, 2000 B18b1 |
TTIWWOP
Ride: 90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
autozone.com has a free repair guide section
get new wires and then check firing order against those manuals... or your helms if you have one, and you def should __________________
I'll blow a hole in your face then go inside and sleep like a baby. |
#6 |
The Trisexual
Timing could be off
#8 |
when we dropped a 95 h22 in a 97 accord we had a problem with the same symtoms .. #1 injectors wernt grounded , #2 dizzy isnt wired right! , just my situation hope it helps ... just because it from ha sport dont mean it is 100 percent.. look into ur wiring more
friction created heat which creates power=does this apply in the word of automotive |
#9 |
RETIRED
timing, compression, fuel and spark are the 4 requirements to get it to turn over/run.
go over all 4 of these 34242 times. something is missing. |
#10 |
'9s Z6 into 89 Dx had same sort of problem ..... would not fire, had fuel and spark. Checked spark plug wires correct (I changed a few times, not sure if they were correct or not). Also, ground wire to engine (near water thermostat housing) was not tightened down properly. After corrected, started no problem (well few minor probs .... but started and ran).
'89 Civic Dx, D16Z6 OBD1 swap GSR Springs, Bilsteins Gravel Rally TSD and RallyX |
