ZC Confusion
Old 05-06-2004, 06:09 PM   #1
Rep Power: 16 aLLmOtOr is off the scale
Hey I was confused about the ZC motors. I want to start a CRX project and I was looking to get a ZC, but what Ive been reading about is that theres alot of variation in the ZC motors. Now the motors from the 88-89 Integra's, are they 130hp or 112hp? Is the only ZC motor that has 130 HP is from the JDM motor? Im sorry if this question been asked already. I just want to get my shit straight. Or should I just scarp the ZC motor and spend a little more on a B18A swap. What do you guys think?
aLLmOtOr is offline   Reply With Quote
Old 05-06-2004, 06:31 PM   #2
Rep Power: 14 90crxb18 is off the scale
Send a message via AIM to 90crxb18
get the B18A my bro has a ZC there close but my car is deffinatly faster and the B18 has more potential, you might just wanna ad a vtec head down the road
90crxb18 is offline   Reply With Quote
Old 05-06-2004, 06:34 PM   #3
Citizen_Insane's Avatar
Rep Power: 51 Citizen_Insane will become famous soon enough
Send a message via AIM to Citizen_Insane
But go with a b18b. I've heard they're much better engines. Also, if you want to upgrade you can always go LS/VTEC with that setup pretty easily. ZC doesn't have much potential compared to B series engines.
No tech questions through PM please!
B16 CRX....you will be missed
Citizen_Insane is offline   Reply With Quote
Old 05-06-2004, 06:45 PM   #4
Rep Power: 29 91crx is a name known to all91crx is a name known to all91crx is a name known to all91crx is a name known to all91crx is a name known to all
i got a b18a i am willing to sell if you want to make an offer, bseries motors definately have alot of potential and b18 happens to be good for turbo or all motor, your choice
91crx is offline   Reply With Quote
Old 05-07-2004, 11:03 AM   #5
my name is Dale
erebunicrx's Avatar
Ride:  cbr 929rr
Rep Power: 35 erebunicrx is an unknown quantity at this point
Send a message via AIM to erebunicrx
deff go with a b18 over a zc. my friend got smoked by a stock neon sohc in his zc. but there are parts for the zc engine. but the b series has more potential.
03 mustang mach1, procharged, built motor, 6sp swap, built rear. 525whp @9psi
00 cbr 929rr 420 conversion -1 +2
erebunicrx is offline   Reply With Quote
Old 05-07-2004, 02:35 PM   #6
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Go with a B if you can afford it. The ZC is still much cheaper, but it's a lot older, has less aftermarket support, and has less ultimate potential. It does make for a pretty fun little Civic though, especially in a 4th gen chassis.
The "ZC" name was given to the highest performing of each type of D series engine in the Japanese market. From 88-91, there was the DOHC ZC that put out about 130hp (118hp ish for olive top or something), and the SOHC ZC that put out about 120hp. There was supposedly a SOHC VTEC ZC from 92-95 that's the same as our USDM D16Z6 (92-95 EX, Si), but I've never seen one in person. The ZC does not exist in any market but the JDM. The only way an engine is truly a ZC is if it has "ZC" stamped on the block casting. Don't anyone else tell you otherwise.
Old 05-07-2004, 02:41 PM   #7
Rep Power: 12 RSBAD454 is off the scale
the civic ZC is 130HP.....BlackTop. dont get these confused with the G1 Integra 86-87 113HP(Brown Top) 88-89 118HP (Black Top) D16A1. The G1 Integra also had the ZC in Japan and NZ.....they came in Brown and Black top as well. You can tell the difference by how the valve cover mounts and how the engine and trannies mount.
RSBAD454 is offline   Reply With Quote
Old 05-07-2004, 03:16 PM   #8
neons are dohc , but they are still neons
Old 05-10-2004, 09:20 PM   #9
Drake's Avatar
Ride:  1991 CRX DX/ Blacktop ZC 5spd Swap
Rep Power: 251 Drake has a reputation beyond reputeDrake has a reputation beyond reputeDrake has a reputation beyond repute
Drake has a reputation beyond reputeDrake has a reputation beyond reputeDrake has a reputation beyond reputeDrake has a reputation beyond reputeDrake has a reputation beyond reputeDrake has a reputation beyond reputeDrake has a reputation beyond repute
Send a message via AIM to Drake Send a message via MSN to Drake  FaceBook
If you are still thinking about going with the ZC check out www.thezcr.com Great information there. Im putting a DOHC ZC into my 91 CRX at the moment. For the cost diffrence between a ZC and a b18 you might beable to put a turbo kit together. That is what i plan on doing that is really the only way the ZC is worth it is if you are going to turbo it. 130 hp from a D series engine is pretty damn good if you ask me. Just my .02 cents. Either way best of luck to you.
XBL GT: Churched V2
H3, CoD 4, CoD: WaW, Forza 2, H3: ODST, CoD 4: MW 2
МОΛΏΝ ΛΑΒΈ
Originally Posted by 95b16coupe View Post
if you are under 16 and prego, you are a lost cause. you are given a life raft and dropped into the ocean to fend for yourself. if you make it back to society, you get $1,000,000 in Arby's coupons.
Drake is offline   Reply With Quote
Old 05-10-2004, 09:43 PM   #10
Rep Power: 14 Projectzc is off the scale
anyone who gets smoked by a neon and they are driveing a ZC powed civic is either a bad driver or they have a beat ZC. There is no excuse for such an atrocity. You have to realize the D series honda engine is very strong and it built properly can yeild a very nice power band.
1988 4dr LX
DOHC ZC
New to the fam 2000 Civic Si
It was towed never to be seen again 88 CRX Si Weep weep..
Projectzc is offline   Reply With Quote
Old 05-10-2004, 09:49 PM   #11
Calesta's Avatar
Ride:  2003 S2000
Yes that's true... but almost any "new" DOHC ZC is pretty beat these days, considering how old they all are.
Old 05-11-2004, 12:21 PM   #12
Rep Power: 0 85CRXsiSlidell is off the scale
Will the ZC bolt up in a 85 crx si? i dunno because everywere i look, its for the second gen crx's....thanks
85CRXsiSlidell is offline   Reply With Quote
Old 05-11-2004, 01:02 PM   #13
TTIWWOP
reckedracing's Avatar
Ride:  90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
Rep Power: 411 reckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
the dohc ZC is a bolt in affair for the 88-91 hatch...
if you have an 85 crx what you want to get is the 86-87 brown top D16A1 dohc integra motor...
the 88-89 black top has 118 horses compared to the 86-87's 113, but if you get the black top you will need to change the distrubutor and such things
86-87 junkyard integra is the best bet... it would help to get the whole car
you will need the integra spindles, discs, calipers, axles, tranny, motor, ecu, and mixed mounts between the crx and the integra...
shift linkage is also helpful but not necessary...
your shifter will sit further back, so first gear would be where 2nd used to be and 2nd will be back even further
takes some getting used to but its not that bad...
you will be pretty happy with this swap and you won't be dumping a lot of money into a car thats that old...
check the forums... either refrence section or articles section for the first gen crx FAQ... it has a little more detail...
and PM me with any questions or search for my pics in the gallery to see what it will look like
good luck
I'll blow a hole in your face then go inside and sleep like a baby.
reckedracing is offline   Reply With Quote
Old 05-11-2004, 01:27 PM   #14
thanka man, ill look into that!
Old 05-15-2004, 01:20 AM   #15
Rep Power: 12 91SiZC is off the scale
I have a SOHC ZC in a 4th gen Si..and i do pretty well.. i can hang with most b16's off the line cause of all the torque.. its a nice setup.. and it was dirt cheap..
91SiZC is offline   Reply With Quote
Old 05-15-2004, 04:45 PM   #16
Rep Power: 13 daidilus is off the scale
yeah i would go with the b-series. they are also a little more durable, i was originally going with a DOHC ZC, but a B16 sell into my lap, and i am much happier, with it, and umm there are more SOHC Neons than DOHC neons
daidilus is offline   Reply With Quote
Old 05-17-2004, 05:26 PM   #17
i have never seen a sohc neon even the lowest and oldest models are dohc
Old 05-17-2004, 07:05 PM   #18
:P
Old 05-17-2004, 07:35 PM   #19
die... thread... die
90 Integra Sedan
B20V 225 / 153
ECU confusion.. dirt817 ECU's, Electronics, and Tuning 3 07-20-2004 09:00 PM
ZC Vtec Confusion cheese9988 HYBRID -> ED-EF / DA 4 05-07-2004 11:14 PM
ecu confusion Seany-izzle ECU's, Electronics, and Tuning 9 03-25-2004 05:42 PM
Tranny Confusion... DA-MAX HYBRID -> EG-EK / DC 2 03-07-2003 04:18 PM
Wiring confusion on 90 CRX DX totalautomotive ECU's, Electronics, and Tuning 2 12-27-2002 07:59 AM
