ZC runnin rich?
Old 06-04-2004, 07:59 PM   #1
Rep Power: 0 CompFX is off the scale
Cool
I did a zc swap into my 91 rex si.. Got it runnin (no problem there).. Its runnin real rich (big problem gettin lightheaded at redlights).. Found a vacuum leak (fixed that problem).. Now its really bad inside the car(get lightheaded drivin) my question is after the swap i had the vacuum leak, Did the ecu set the air/fuel mix with the vacuum leak making it heavy on the fuel? If so how do i fix it (reprogram the ecu w/o a vacuum leak)..
Humor me im feelin a little retarded right now still buzzed from the drive home...
CompFX is offline   Reply With Quote
Old 06-04-2004, 08:10 PM   #2
cheese9988's Avatar
Ride:  2007 Chevrolet Cobalt SS Supercharged
Rep Power: 28 cheese9988 will become famous soon enough
Its a common thing with zc's appartently...is it throwing any codes? Mine was running real rich until I fixed the tps sensor, I fixed that and it still runs slightly rich. It has a pm7 ecu made for the motor too.
Is it good when my dipstick is rusty on my jeep?
Stupid is standing in line for a lottery ticket while telling your buddy your vote doesn't count.
"The only man who makes no mistakes is the man who never does anything. Do not be afraid to make mistakes providing you do not make the same one twice."
Theodore Roosevelt
http://homemodders.com/t188/
cheese9988 is offline   Reply With Quote
Old 06-04-2004, 08:13 PM   #3
Its not throwin any codes but it is loading up at idle
Old 06-04-2004, 08:35 PM   #4
cheese9988's Avatar
Loading up? meaning the idle is high? When mine is cold it starts up around 2000rpm and then when it warms up it drops to around 1000rpm.
Theodore Roosevelt
Old 06-04-2004, 08:46 PM   #5
Loading up=to much fuel not enough air.. My idle stays around 900(after it warms up) but when i stop or when it winds down from a high rev it stumbles a little (loads up with fuel) sputters then idles fine but still rich..
Old 06-04-2004, 08:50 PM   #6
cheese9988's Avatar
Did you replace the o2 sensor, I got a universal from autozone <$30.
Theodore Roosevelt
Old 06-04-2004, 08:55 PM   #7
Ya replaced 0/2 , plugs , cap , wires using si intake ,injectors and dizzy..CAI,Header,high flow cat,aftermarket catback..
Old 06-04-2004, 09:59 PM   #8
cheese9988's Avatar
Dunno, mine still runs a little rich but not as bad as before. Before you could smell the fuel, now I can't. I'm running stock zc, stock intake, stock zc manifold, downpipe, bored out cat, new si exauhst front to back, new plugs, new o2 sensor, new tps sensor, pm7 ecu, new cap/rotor. I like the stock look of the car, thats why I bought it, so I am trying to keep everything the same. Basically I am just rebuilding it.
Theodore Roosevelt
Old 06-04-2004, 10:19 PM   #9
Koo not anything wrong with the stock look..Mine is all stock exterior stock height stock wheels,been wrecked and fixed so right now it is multi colored.. I like it that way almost a sleeper look except the melon shooter hangin out the back of it...
Old 06-04-2004, 10:25 PM   #10
cheese9988's Avatar
I ended up repainting mine, paints expensive....until you get a quote from a body shop.
Theodore Roosevelt
Old 06-05-2004, 04:48 PM   #11
I got it only took a lil research..
Forum Jump
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
