Ok my friend has a d16z6 in a 91 civic hatch. The civic has the base 4spd manual tranny (I believe it's the STD model). We are having a prob finding a CRX Si tranny.
I was thinking could we use a ZC tranny w/ LSD in the Civic. I belive we have to use the Integra even axles, and DX hubs. Is this right? does the ZC even bolt on to the d16z6 motor? Some one school me on these trannys please __________________
-92 civic w/ 97 B18C-R I/H/E traction bar 13.893@ 98.52mph -95 LS Integra I/H Beater car (Rear ended RIP) 15.62@ 86.27 -00 Civic Si I (my DD) b16 SiR-II swap |
Ride: 88 Honda Civic HB
Yes, you can use the ZC transmission with LSD in the Civic; although the (equal length) ZC axles are the correct one and DX hub is required with those axles. An alternative is just swapping out the differential in the ZC transmission for a 88-98 Si one and using the stock axles.
Yes, the ZC bolts onto the D16Z6. The ZC is pretty much a D16A6. __________________
Ok the DX hubs should be a easy junkyard pick-up.
On the axles we may have to buy new, I dont recall seeing any ZC's in the yard. I was hoping I could use DA axles and half shaft. The plan is to get the ZC and then a hydro Si final drive, would the 92-95 Si FD work with the ZC LSD? __________________
#4 | |
the DA intermediate shaft will not work with the D-series engine - the bolt pattern where it bolts to the back of the block is different - only the JDM ZC intermediate shaft will work - also, the D16Z6 block does not have the holes tapped in the back of the block to bolt the intermediate shaft on
finding a ZC transmission with LSD is going to be tough as most ZC transmissions don't have LSD __________________
ZCspeed Racing Last edited by jlicrx; 09-08-2008 at 01:12 PM. |
#5 | |
![]() So if the ZC tranny intermediate shaft will work, does it not bolt to the back of the block? Found the tranny from Hmotorsonline this is thier description: "ZC DOHC LSD Cable Transmission - 5 Speed Trasmission, Will only work with ZC SOHC or DOHC" __________________
#6 |
Actually, that is incorrect. A 92-95 differential will indeed work in a L3 transmission. I have a 92-95 EX differential in my DOHC ZC transmission and had zero issues. Just make sure it is shimmed correctly. Transzex even suggested using 92-95 differentials due to it eliminating the differential pin issues found in the 88-91 differentials.
#7 | |
Their description is somewhat true. The SOHC ZC is pretty much a D16A6, and the bolt patterns between the 88-00 D-series are the same. I have a DOHC ZC transmission mated to a D15B-VTEC...a D16Z6 "equivilant." Where the difference lays is the intermediate shaft. The ZC's already have the holes threaded and everything for the half shalf IIRC. A simple differential swap or installing a intermediate shaft will make it work. __________________
#8 | |
ZCspeed Racing Last edited by jlicrx; 09-09-2008 at 11:40 AM. |
#9 | |
![]() I guess misreading something means I don't know shit; please disregarded all of my posts. __________________
1988 Honda Civic Standard-more mods than I want to list 1992 Honda Accord LX 1996 Toyota Avalon-Spun bearing, for sale. Terrorists have successfully attacked our imagination. RIP Jon Eban Nie, August 31, 1991 - May 7, 2006 Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006 Last edited by K2e2vin; 09-09-2008 at 12:13 PM. |
| WTB: D16Z6 w/ or w/o tranny | dropsickle | Parts: For Sale/Trade/Wanted | 8 | 05-15-2008 10:17 PM |
| Best D16z6 Tranny | chrono404 | Civic and del Sol - EG and EK | 8 | 09-17-2007 07:10 PM |
| 93 Del Sol Si Tranny D16z6 | H22DelSol | Parts: For Sale/Trade/Wanted | 3 | 12-12-2003 09:49 PM |
| 92 si d16z6 tranny | 12secb16a2hatch | Parts: For Sale/Trade/Wanted | 0 | 11-21-2003 12:58 AM |
| D16z6 And Tranny F/s! | sohcslammer | Parts: For Sale/Trade/Wanted | 13 | 04-24-2003 03:53 PM |
