00 b16 in 98 hatch
Old 07-30-2008, 12:03 AM   #1
Rep Power: 3 ANIMOsity is on a distinguished road
Default 00 b16 in 98 hatch
im using the engine harness that came with the motor and the car runs. It's just that my certain things don't work like the tach, speedo, odo, a/c, radiator fan, and the fuel pump relay doesn't click off when it's on the ON position.
Is there a way to re-wire the obd2b engine harness to work with my 98 civic (obd2a)?
ANIMOsity is offline   Reply With Quote
Old 07-30-2008, 12:26 AM   #2
Powerd With 1 Cam
JDMB20Coupe's Avatar
Ride:  95 EG Coupe
Rep Power: 0 JDMB20Coupe is infamous around these partsJDMB20Coupe is infamous around these parts
Send a message via AIM to JDMB20Coupe myspace
check the harness for breakes or striped spotts
$Me & Megan$
Never think, just pull the trigger.
Originally Posted by efhondakid
"Im so JDM I sleep on the right side of the bed"
God Created Turbo Lag to Give V8s a Chance!
JDMB20Coupe is offline   Reply With Quote
Old 07-30-2008, 12:45 AM   #3
there shouldn't be any breaks in the harness but i'll check. If i did my research right, the problem is that i'm using a obd2b harness in the obd2a car. so i was wondering if there was any way at all to rewire the obd2b harness to work with a obd2a car.
Old 07-30-2008, 06:06 PM   #4
Ride:  97 SOHC VTEC Hatch
Rep Power: 10 ilubmyEG will become famous soon enoughilubmyEG will become famous soon enough
myspace
You using a OBD2a or b ECU?
ilubmyEG is offline   Reply With Quote
Old 07-30-2008, 11:08 PM   #5
ecu and harness is obd2b
Old 08-01-2008, 01:34 PM   #6
myspace
This is one of the swaps I think that are not reccommended. What you need to do is get a jumper harness and convert it to obd1, or run a stock ecu with a jumper harness to obd2a
Old 08-01-2008, 11:26 PM   #7
I've already tried a obd2b - obd1 jumper harness with a chipped ecu...nothing changed. I'm guessing the problem is on the driver side of the engine harness but I could be wrong. Does anybody know where I can get a wiring diagram/schematics of both obd2a and obd2b harnesses?
Old 08-05-2008, 12:44 AM   #8
bump
Old 08-05-2008, 05:38 AM   #9
Rep Power: 0 92eg_hatch is on a distinguished road
no your problem is you need a 96-98 honda civic ex wiring harness (obd2a) and put it on the 00 b16..you just have to extend your O2 sensor and you have to change one sensor i cant think off hand which one it is from a 3 plug to a 2 plug.....then you put an obd2a to obd1 jumper harness with obd1 ecu...or you could just rewire your whole car for a 99-00 si your call...been there done that..i had a 97 civic dx coupe with a jdm sir II b16a in it wit a junk harness so i went to honda and spent like 500 bux on a 99 si harness and come to find out that it wasnt gonna work so i ate 500 bux
92eg_hatch is offline   Reply With Quote
Honda : Civic DX HATCH EK HATCH W/B18C1 SWAP!! TODA, MUGEN, SKUNK 2, TYPE R RSS-Bot Auctions 0 12-27-2007 08:43 PM
94 civic hatch hatch tomogchi Civic and del Sol - EG and EK 4 04-24-2007 01:50 AM
WTT my Allmotor LSVTEC hatch for eg coupe or hatch david_jones001 Vehicles: For Sale/Trade/Wanted 5 04-24-2005 08:16 PM
ls turbo hatch vs itr hatch b18hatch9 Auto Multi-Media 0 12-27-2004 01:48 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
