00 Si (b16a2) to 93 si Swap ?'s
Old 08-04-2003, 06:35 PM   #1
Rep Power: 0 marklar182 is off the scale
Thumbs up
Usually I'm pretty good about using the search buttons but there is so much contradicting info out there so I'll ask some experts!
Donor Engine/tranny- B16a2 (390hp turbo) from a 00 Si
Recipient- 93 Civic Si hatch
ECU- P28 chipped w/ Hondata Stage 4b
axles- Driveshaftshop.com 00 Si
?'s
1. Motor mounts. Is this a direct swap or are different mounts needed? I've read both ways so far. Looks like a direct swap to me though.
2. Engine wire harness. Can the 00 Si harness be used? I know it is an obd2 harness but the p28 ecu worked with the obd2 engine. Do not want to swap out the dizzy($$$). Is there any other harnesses that will work? Is it practical to remove the complete harness(from ecu on) from the 00 Si to the 93 Si?
TIA
marklar182 is offline   Reply With Quote
Old 08-05-2003, 02:40 AM   #2
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 541 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
a 3rd gen integra GSR or ITR engine harness will work perfectly or you can mod yours to work
i think you need to use 3rd gen teg mounts (im not 100% sure on this though there might be a way to get yours/the Si ones to work)
МОΛΏΝ ΛΑΒΈ
Old 08-05-2003, 09:23 PM   #3
Thanks E_SolSi
Any others?
Del Sol S D15B7 to D16y8 swap question oakley2002@cox.net HYBRID -> EG-EK / DC 1 01-21-2004 01:32 PM
Civic D16 > B16A2 Swap Question SIdun HYBRID -> EG-EK / DC 0 01-04-2004 01:51 PM
99 00 Si B16a2 Swap Cheap DeviateRacing Parts: For Sale/Trade/Wanted 2 03-17-2003 11:42 PM
Civic Si 92 With D16a9 Swap -> B16a2 shafagh HYBRID -> EG-EK / DC 1 02-25-2003 06:20 PM
