00 Si Clutch Help
Old 08-05-2003, 04:01 PM   #1
Rep Power: 14 Hatchback 95 hybrid is off the scale
Send a message via AIM to Hatchback 95 hybrid Send a message via MSN to Hatchback 95 hybrid Send a message via Yahoo to Hatchback 95 hybrid
Sup everybody anybody got information how to change the cluth on 00 si doch vtec transmission just anything will help me thanx
Hatchback 95 hybrid is offline   Reply With Quote
Old 08-05-2003, 04:03 PM   #2
Rep Power: 18 khai_tuan_nguyen is off the scale
You have to take the whole tranny out to start with
<a href=\'http://www.hondaswap.com/forums/index.php?act=module&module=gallery &cmd=user&user=25607&op=view_album& album=107\' target=\'_blank\'>PICTURES: Type R Stuff/ B-Series Parts for Sale</a>
khai_tuan_nguyen is offline   Reply With Quote
Old 08-05-2003, 04:11 PM   #3
is all out been out i just wanna know how to install a new one
Old 08-05-2003, 05:26 PM   #4
Rep Power: 0 marklar182 is off the scale
For starters go out and get a Haynes manual. We used that bad boy to tear down and rebuild a 00 SI.
Unbolt the pressure plate from the flywheel, remove the clutch plate. Check the flywheel surface for damage, resurface if needed. Pull and replace the pilot bearing. Clean the flywheel with brake parts cleaner. Using a clutch alignment tool put on the clutch plate and bolt the pressure plate back on. Tourqe to spec. Change throwout bearing on tranny. Reinstall tranny.
marklar182 is offline   Reply With Quote
Old 08-05-2003, 07:46 PM   #5
thanx =]
clutch problem after swap welfare HYBRID -> EG-EK / DC 0 05-12-2004 11:51 PM
My transmission or clutch is acting up La_Pieuvre General Tech and Maintenance 6 02-06-2004 02:40 AM
My clutch isn't engaging! MarkJimenez99 General Tech and Maintenance 22 12-27-2003 11:25 AM
new clutch and flywheel rsaeini Engine Building 1 10-06-2003 04:54 PM
NOPI.com rsaeini Members' Lounge 22 10-02-2003 03:07 PM
