01 Gsr Swap To 95 Civic Dx.. Hellp???????
Old 12-27-2006, 03:15 PM   #1
Rep Power: 0 socojo2002 is on a distinguished road
Default 01 Gsr Swap To 95 Civic Dx.. Hellp???????
I Have A 95 Civic Dx That I Am Putting A 01 Gsr Engine And Ecu.
My Question Is What Is The Best Route To Go With When Doing The Wiring For The :
--ecu,
--engine,
--distributer
And All The Others That I Have No Clue About??????????
socojo2002 is offline   Reply With Quote
Old 12-27-2006, 04:36 PM   #2
Blah blah blah....
MikeBergy's Avatar
Rep Power: 49 MikeBergy is on a distinguished road
Send a message via AIM to MikeBergy
Use an obd1 distributor from an integra GSR or civic del sol vtec. The distributor part number is TD-68U, and here is an ebay link to show you what it looks like. eBay Motors: NEW DISTRIBUTOR OBD1 INTEGRA 92 93 94 95 GSR W/ VTEC (item 110072088189 end time Jan-01-07 11:05:00 PST)
Go with an obd1 p28 ecu that has been chipped with a stock gsr program on it. I highly recommend buying from Chris Harris at Xenocron.com. He is an awesome and very helpful guy and will support you by trying to answer any engine management questions you might have, and his prices are very reasonable. He also sells any tuning equipment you might need in the future after you've figured some stuff out. The p28 won't run your iab's, but there might be a mod that allows them to be run off a p28. I'm not sure tho, that is a question for Chris. You can also run an obd1 p72 ecu from a 94-95 gsr if you want an ecu that will run your engine well straight from the factory.
Most of the sensors on the engine should be the same as on your dx engine, but the gsr engine you bought will have a knock sensor on it. The p28 ecu will not look for this sensor, but the p72 will.
I'm sure others will chime in on this, so just be patient, and do some research while you are putting your swap plan in motion, and I'm sure you'll do fine.
-1991 Integra, lots of goodies in an otherwise stock looking motorp; ITR front brakes.
-Xenocron programmable ecu w/datalogging port, LM-1 wideband, and Moates Ostrich are tuning tools of choice.
RIP 2005 Red Yamaha R6
www.m24x.com - Rocket Motorsports: For more technical engine discussions...
Radar will bounce off of a ride that is shiny and you keep clean.
Please don't PM me with tech questions. Use the forums!
MikeBergy is offline   Reply With Quote
Old 12-28-2006, 09:33 AM   #3
Thanks for your post, its very helpful but I still would like to use the 01 gsr ecu, and i have already bought a ecu adapter and if possible, i would also like to use the 01 distributer. Again thanks for your help, if nothing else goes I'll have something to fall on.
Old 12-29-2006, 02:17 AM   #4
Blah blah blah....
MikeBergy's Avatar
Why would you run an obd2 ecu when the obd1 ecu runs the engine exactly the same? The obd2 ecu also is untunable, more expensive, and, as you said, requires a harness that nobody makes - you probably bought an obd2 -> obd1 adapter, but I guess I could be wrong. I've certainly never seen one. Nobody switches from obd1 to obd2, there is no reason to. If you run the obd2 ecu, you'll need obd2 electrical components. But good luck.
Old 12-29-2006, 02:22 AM   #5
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
Yeah there really is no need to switch to obd2..
Matts96HB is offline   Reply With Quote
Old 12-29-2006, 09:40 AM   #6
Default hmmmm............
Well ill give you guys more information.. I have already done the swap, and I redid the engine wire harness from the 95 civic, but its not getting any fire or fuel and it might be because I switched the plugs from the 95 civic to the 01 distributer, so maybe thats whats wrong with it.. I appriciate your guys help, but maybe im on my own on this one!
Old 12-29-2006, 09:07 PM   #7
Blah blah blah....
MikeBergy's Avatar
If you messed with the stock harness, I can't help you much. Anything could be wrong, and I couldn't help you without looking at it in person.
Help me choose Civic for engine swap arielb1 General Tech and Maintenance 16 06-17-2004 11:59 AM
B20B from CRV into 92-95 Civic SI SWAP hondacivicnos HYBRID -> EG-EK / DC 6 10-08-2003 12:33 PM
Need some help with Trim Names YangpaNemsay General Tech and Maintenance 7 08-31-2003 04:43 PM
Chassis Code VSMB16A2 General Tech and Maintenance 10 01-22-2003 05:32 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
