1st gen b16a into 92 si questions please help!!
Old 07-30-2004, 01:22 AM   #1
Rep Power: 0 calhoun is off the scale
ok i know this is not a swap you are supposed to do but i have the engine in my crx and want a nicer car. so i want to put it in a 92 si shell i found. can it be done? i seached so please dont tell me to i know i am new but i could not find much info on this swap. i know my car has a cable tranny and the hatch had a hydro. if possible what else am i ging to need other then my running engine?
also i blieve the car curently has a integra tranny in it because there is a shaft coming out of it before the axle on the driver side and i have never seen this on any other b16a's. any help would be appreciated
thanks, chris
calhoun is offline   Reply With Quote
Old 07-30-2004, 01:34 AM   #2
Rep Power: 14 mrnice1058 is off the scale
Send a message via AIM to mrnice1058
well you can use your b16a in your 92 all you need to do is one of two things
1 get a cable to hydro tranny convertion kit from hasport or
2 sell your tranny and get a hydro tranny
also i am not sure but i think your shift linkage will not work on your car from the 91 but you can try if not check your local junk yard for a 92 and up b16 civic (not del sol) or a 94 and up integra
started but running pretty rought have any advise pm me and let me know!!
mrnice1058 is offline   Reply With Quote
Old 07-30-2004, 01:41 AM   #3
in the not recomended swap tech it was saying wiring would be a nightmare why is this?
Forum Jump
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
