2 Swap questions
Old 01-22-2004, 10:51 PM   #1
Ride:  Del Sol
Rep Power: 14 dwn2low is off the scale
OK,
I am swapping my DX 1.5 out for a d16z6 and was wondering the following. Civic is 5th gen
1. What is the diffrence between an EX and a DX wiring Harness?
2. What ECU's can I run with my d16z6 swap?
dwn2low is offline   Reply With Quote
Old 01-22-2004, 11:01 PM   #2
Rep Power: 49 Slammed90Lude is an unknown quantity at this point
Send a message via AIM to Slammed90Lude
what year is it?
that's imortant cause all EX's were wired for Vtec but only 92 DX's were wired for vtec- also the motor is designed for the P28 ECu and i'm not sure what else you could use-
Slammed90Lude is offline   Reply With Quote
Old 01-22-2004, 11:09 PM   #3
Ride:  Del Sol
it is a 93 so I know I need to run 2 wires from the engine to the ECU. is that the only diffrence?
Old 01-23-2004, 05:20 PM   #4
supposing you use the P28 ecu then yeah- there is a good article on it in the swap section- someplace in there i think
Old 01-23-2004, 06:43 PM   #5
Kung Foolin'
Ride:  1990 Integra GS
Rep Power: 32 StealthMode is on a distinguished road
Send a message via AIM to StealthMode
i did the same swap in my 94 CX recently. i used a p28 ecu, and had to run 2 wires from my ecu to the plugs where the wirin harness hooks up. i encountered some bullshit though, but that's because the harness i used had been cut at the base of the wires running to the distributor by some dirty bastards. so i had to splice in my distributor wires off the cx harness in to the EX harness. the other civics were wired for VTEC except for the cx, but it wasn't hard to run the extra wires. hope you enjoy your swap as much as i do.
On a quiet night, you can hear a d-series ninja being born. . .
StealthMode is offline   Reply With Quote
Old 01-24-2004, 12:00 AM   #6
Ride:  Del Sol
Tnx guys for the help
Old 01-24-2004, 10:05 AM   #7
Ride:  93 del Sol Gas sipper
Rep Power: 95 asmallsol will become famous soon enoughasmallsol will become famous soon enough
what everyone else said is right. I did a swap on a auto DX to a manual d16z6, and the only wiring that we had to do was for VTEC, which is pretty easy.
Collin
Material Science and Engineering
Michigan Technological University
Old 01-28-2004, 07:06 PM   #8
Rep Power: 10 civicext is off the scale
when i sold my motor to this guy that got my old motor he went to honda to get the harness cause he did not want to wirer the the vtec in for the d16..
civicext is offline   Reply With Quote
Old 01-28-2004, 07:53 PM   #9
sorry, it had to be done
Old 01-29-2004, 10:26 AM   #10
I kinda doubt that because the wires that your adding are from the shock tower harness's to the ECU. this mean that he would have to rip out a shit load of wires, and it would be a hell of alot more work. It is hard enough to send the two wires through the fire wall, a hole harness would be almost impossible.
Collin
Forum Jump
B18C swap in 91 crx Si, lots of questions 99SH HYBRID -> ED-EF / DA 1 03-26-2004 03:06 PM
4th Gen Civic ZC Swap questions Aquariust HYBRID -> ED-EF / DA 8 01-19-2004 11:01 AM
General Swap Questions Canuck 93 Civic Si HYBRID -> EG-EK / DC 1 10-10-2002 09:33 PM
head swap questions toyzbus HYBRID -> EG-EK / DC 7 10-10-2002 12:17 AM
B18 swap questions Canuck 93 Civic Si HYBRID -> EG-EK / DC 3 10-03-2002 08:56 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
