2 valves per cylinder to 4 valves
Old 02-11-2005, 06:51 PM   #1
Rep Power: 15 DelSlo is off the scale
i got a 94 cx hatchback, i took off a bad head, the two valves per cylinder one and got a 4 valve one off a 94 car as well, now the freaking thing wont start.. i got spark and i got fuel pressure and my ecu isgrounding out the injectors, it sounds like a timing problem, but hell its only a sohc and it was spot on. i quadruple checked my wires and they are good, 1 3 4 2. anyone ever swapped heads like this, is there something ive overlooked???
93' Del Sol
2000 B16A2 swap.
garrett T3/T4 (.48/.60)
Weapons of choice.. Innovate LC1 and Crome Pro
Faze EL Engine management guages.
DelSlo is offline   Reply With Quote
Old 02-11-2005, 07:19 PM   #2
im gonna do a leak down test and a compression test on it tommorow morning and go from there i geuss, i got a feeling its got very little compression, i did a compression test before removing the head and it read 165 psi across all 4 cylinders, we'll see where its at tommorow with this new head. i got a good fuckin feeling im gonna have to drop in my old d16z6 motor just to sell this thing!!
will the d15 tranny bolt to the d16z6 block alright??
93' Del Sol
2000 B16A2 swap.
Old 02-11-2005, 07:40 PM   #3
Rep Power: 26 projectxspeed is off the scale
Send a message via AIM to projectxspeed Send a message via Yahoo to projectxspeed
Yes the d15 tranny will bolt up to your d16z6 block
<a href=\'http://home.comcast.net/~projectxspeed/3rdgenteg.htm\' target=\'_blank\'>A Project in Progress</a>
Get your ECU CHIPPED / buy ECU's CHEAP (uberdata, custom ecu maps, and more): <a href=\'http://www.hondaswap.com/forums/index.php?act=Msg&CODE=04&MID=36429 \' target=\'_blank\'>PROJEKTEG</a>
projectxspeed is offline   Reply With Quote
Old 02-11-2005, 08:03 PM   #4
cool, thanx
93' Del Sol
2000 B16A2 swap.
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
