2000 si b16a2 obd2 into 92 cx
Old 12-08-2003, 05:22 PM   #1
Rep Power: 0 jdmrhdeg6 is off the scale
how do i wire an obd2 engine into an obd1 car without changing the dis. , intake manifold, injectors and engine harness
jdmrhdeg6 is offline   Reply With Quote
Old 12-08-2003, 08:52 PM   #2
FüK-VTEC
civicious's Avatar
Ride:  07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
Rep Power: 189 civicious has a reputation beyond reputecivicious has a reputation beyond repute
civicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond reputecivicious has a reputation beyond repute
Send a message via AIM to civicious myspace
um....
you don't.
you're going to at LEAST have to change the engine harness.
if you dont want to convert it to obd1, youre gonna have to:
1. hack your dizzy
2. hack your injectors
which might not work, and will probably look like shit.
just buy an obd1 dizzy and obd1 injectors.
also, you can use your stock obd1 ecu if you absolutely have to, but it'll be shitty.
best bet is to get a p30 or a chipped p28, or get an obd1-obd2 jumper and use the 99-00 Si ecu.
CMRA #265
http://www.myspace.com/civicious
AIM: greyfades
civicious is offline   Reply With Quote
Old 12-08-2003, 11:53 PM   #3
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 569 E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
1st question is do you have the OBD-2 harness???
if you do i can give you full instructions on what plugs need to be swapped out
МОΛΏΝ ΛΑΒΈ
E_SolSi is online now   Reply With Quote
Old 12-09-2003, 12:02 AM   #4
FüK-VTEC
civicious's Avatar
he'd still have to use an obd1 engine harness thogh.
obd2 civic harnesses are 1-piece
obd1 civic harnesses are 2-piece
unless he wants to put an obd2 in-car harness in.
CMRA #265
AIM: greyfades
Old 12-09-2003, 12:23 AM   #5
E_SolSi's Avatar
no shit .... but you can simply swap the plugs for the distributor, injectors, and alternator from the OBD-2 harness to the OBD-1 harness
its quite easy
then use wire from the OBD-2 harness to extend the few plugs that dont quite reach
this is how i wired the ITR engine up in my sol
МОΛΏΝ ΛΑΒΈ
Old 12-09-2003, 12:44 AM   #6
FüK-VTEC
civicious's Avatar
OH
mah bad
i misunderstood
dammit, working from noon until now almost nonstop on fuckin' college homework is kicking my ass.
CMRA #265
AIM: greyfades
Old 12-11-2003, 02:52 PM   #7
Rep Power: 0 marklar182 is off the scale
I agree, use the obd1 harness and swap the dizzy plugs, injector plugs(I have RC's and did not need to change plugs), and alternator plug. The wires are the same colors so just repin them to the new harnesses. You will have 2 dizzy plugs instead of 1. Then lengthen the O2 plug to the rear of the motor instead of the front. I did this same swap, a 00 Si b16a2 to a 93 CX. If I recall you will already have a Vtec wire from the ECU to the engine bay already since its a 92, but dont forget to check. I have a Canuck (canada) 93 and it had the Vtec pre wired. I also have detailed instructions if you need (given to me from a fellow hondaswap.com'er.) email if you have more ?'s.
marklar182 is offline   Reply With Quote
Old 12-25-2003, 02:59 PM   #8
i have an extra sohc v-tec harness and ecu laying around can those be of any use in this?
Digitally Imported Trance Cashizslick Members' Lounge 12 02-20-2005 04:40 AM
WTB: 2000 b16a2 block 2000Si Parts: For Sale/Trade/Wanted 4 05-10-2004 04:12 AM
Can I use the 99 CX harness for the B16a2 OBD2 99 Civic hatch SI HYBRID -> EG-EK / DC 4 08-19-2003 08:21 PM
B16a2 Obd2 Auto? CIVIXER HYBRID -> EG-EK / DC 4 06-02-2003 03:53 PM
Civic Dx Obd1 N B16a2 Obd2 civicgRim_rIppeR HYBRID -> EG-EK / DC 0 02-06-2003 12:08 AM
